SolaraGuy.com • View topic - tinting problem
tinting problem
tinting problem
Postby retarded » Wed Oct 29, 2003 4:38 pm
i just got my 04 solara tinted w/ a 5% tint on the rear window and 20% on the rear side windows. After a few days I left it to dry, and smooth out, but on the top portion of the rear window is a darker black strip which left a bad job on the tint, what should I do to fix the tinting job?
retarded
Postby slingshot » Wed Oct 29, 2003 4:55 pm
Sounds to me like the tinter tried to tint over the infamous black dots on the top of the windshield. Doing that is like tossing a coin over how well it will adhere. There are some tricks tinters use to make it stick better to dots - some sand them down with very fine sandpaper,etc. If you don't want to do that and it isn't sticking well, you could always have them cut away that topmost section. From the outside, it probably won't be too noticeable though I'm not sure on this car....
Dave
slingshot
Postby slingshot » Wed Oct 29, 2003 4:58 pm
To those who have tinted the back window on their 2004 Solara:
Did you tint over the topmost black dotted area on the back window?
If so, did the tinter have to sand down the dots or do anything else special?
If the tinter skipped the top section, how does it look from the outside?
How does it look from the inside?
Thanks in advance,
Dave
slingshot
Postby cruze105 » Wed Oct 29, 2003 5:27 pm
give it couple of days so it can even out and dry i had the same problem, and after a like 2 weeks it started to get unnoticeable by the dots. There is no such thing as a perfect tinting job. you will always see some small imperfections.
jus my .02 cents :roll:
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
nice sig
Postby bigpow » Wed Oct 29, 2003 5:47 pm
Nice signature, Compusa boy.
retarded, please tell us what's the outcome.
bigpow
Postby retarded » Thu Oct 30, 2003 9:35 am
I had the tinting job about 3-4 weeks ago, and the tinter told me to wait for about a week or two for it to dry. Yes, it was the black dots in the top portion of the rear window that did not smooth out. They did try sanding out, and it was still a messy job. THe good thing is I get to come back and see what they could do to fix it. One alternative is suggested was to have the rear window a 0% tint, so that the top portion would look better, but 0% is a bit too dark..haha. Any other suggestions before I take it back???
retarded
Postby retarded » Thu Oct 30, 2003 9:36 am
oh, and by the way, do the black dots on the rear window serve any purpose?
retarded
Postby Blazed04 » Thu Oct 30, 2003 10:16 am
Also guys, im getting my tints done tomorrow (Friday) and i dont want them to tint around the 3rd brake light. But i just figured out this morning that the whole 3rd brake light is attached to the rear deck! WTF!! Im definitely getting my tints done, but i hate the look of when they tint around the 3rd brake light. S H I T ! anyone got any suggestions??
Lunar Mist '04 SE Sport V6
2001 GSXR 750
Blazed04
Postby retarded » Thu Oct 30, 2003 11:23 am
blazed tell me how it goes after your tinting job and the the black dots on the top of your rear window. For your rear third light, what they should do (what they did with mine), is remove the panels above your rear seats so that they are able to tint the whole window, and not around the light. This was why so many places were charging me more for labor because of this
"extra" job. As far as the black dots, tell me what they did to fix that.
retarded
Postby Guest » Thu Oct 30, 2003 11:30 am
Retarded,
I have an Artic White SE as well. Do you have any pics of your car? I was thinking of only thinking about going 35% all around, and didn't know if it would be dark enough.
Guest
Postby Guest » Fri Oct 31, 2003 12:12 pm
yeah "guest", 35 % is a lil too light for my taste, ill try to post some pictures soon. 20% all around would look pretty smooth for the car
Guest
