SolaraGuy.com • View topic - car noob question
car noob question
car noob question
Postby chuchurocket » Sat Nov 01, 2003 10:14 am
can someone tell me what's the use of "over drive" on the solara is for, cuz i never use it aand i odn't know whether improper use will damage my 2 days old solara or not thanks
chuchurocket
Postby Jackass-Jeff » Sat Nov 01, 2003 10:47 am
#1 Overdrive is ALWAYS on =]
Your car is a 5 speed automatic... that means that the first 4 gears are for driving and 5th is for overdrive. Overdrive shifts the tranny sooner so you save my gas by using a higher gear and don't go to higher revs. If you turn O/D off, you will notice that you'll naturally rev higher than you did before.
#2 Keeping it on is better unless you need power to go up a hill (although ECT-i should auto-adjust the gear so you maintain power on uphills)
#3 It's ok to ask if you don't know =] But please use the "Search" function first... almost everything most people ask have been asked time and time again! =]
1GR-FE ftw!
Jackass-Jeff
Postby chuchurocket » Sat Nov 01, 2003 4:18 pm
sorry i didny specify, but mine is the 2.4L 4 speed one, and i am just curious about ,when, or why should i shift into the 2,3,and L
chuchurocket
Postby Jackass-Jeff » Sun Nov 02, 2003 12:56 am
Same idea but only 3 gears are driving and 4th is OD... L 2 3 is for uphill climbs but the ECT-i adjust gears... the 4-banger Gen 2 feels so sluggish compared to the gen 1.5 4 banger =x
1GR-FE ftw!
Jackass-Jeff
