SolaraGuy.com • View topic - Adding speakers
Adding speakers
Adding speakers
Postby Pingi3 » Mon Nov 10, 2003 10:37 pm
im going to replace the factory speakers this weekend, does anyone have any tips on how to remove the door panels and the 2 rear speakers?
Pingi3
Postby HKSV6SLE » Tue Nov 11, 2003 12:13 pm
hmmm wrong section and since you posting in this forum im assuiming you have an 04 solara....the old generation solara's were time consuming when removing the rear panels to change the rear deck, the door should be easy.
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
fac JBLs are pretty good
Postby ani_solara » Wed Nov 19, 2003 2:59 pm
I dunno if you have the "premium" JBL sound system, but if you do, then you might want to rethink replacing those speakers. Those are not bad at all. I might end up replacing them in my car just because I'm a car audio fanatic, but if I do end up replacing them, I would get something like MBQuartz or the new Boston 6.5 Pro Series, you'd have to replace them with something high quality like that to get better then the JBL.
And if you end up replacing them with high quality components, then you better end up replacing the factory headunit, which is pretty hard to do right now as there is no Toyota dash kit yet (right?) for the 04's.
ani
2004 SLE V6
ani_solara
Postby VirtualSlayer » Wed Nov 19, 2003 5:44 pm
The guy that worked at Toyota said that the JBL doesn't really improve your sound system. They mainly just upgrade your headunit. Not really worth the extra 600 bux
VirtualSlayer
Postby Pingi3 » Thu Nov 20, 2003 1:41 pm
I only have the standard radio...but i already changed the rear speakers. you have to remove the rear side panels in order to remove the rear dash, because the parts interlock with eachother. I replace the speakers with some Pioneers and it really does sound better.
Pingi3
Postby Blazed04 » Sun Nov 23, 2003 4:52 pm
Just wondering what sizes our speakers are? Rear & Front . . . ?
Lunar Mist '04 SE Sport V6
2001 GSXR 750
Blazed04
Postby kubi » Sun Nov 23, 2003 4:54 pm
As long as the 04 is the same, which I see no reason for it not to be... the fronts are 6.5" and the rears are 6x9.
kubi
Postby Pingi3 » Sun Nov 23, 2003 6:15 pm
yeah... its 6.5 in the front and 6x9 in the rear.
Pingi3
tweets?
Postby ani_solara » Mon Nov 24, 2003 4:43 pm
aren't there tweeters in the front dash? or is that just an empty grill at the front of the dash near the winshield?
ani_solara
Postby kubi » Mon Nov 24, 2003 10:15 pm
ya the tweeters are in the door top of the door. 1" i believe
Please stop humping my car, owner privilege!
kubi
