SolaraGuy.com • View topic - Removing Rear Panel
Removing Rear Panel
Removing Rear Panel
Postby TW85 » Thu Nov 13, 2003 12:09 pm
I have a rattle somewhere in the rear of my car. I think it is coming from underneath the rear panel (panel above speakers) and I cannot for the life of me figure out how to remove it. Toyota seems to have designed it so that all panels interlock and that is my biggest problem. Have any of you removed it?
TW85
Postby bigpow » Fri Nov 14, 2003 10:56 am
I had the dealer replaced the whole trim panel.
It should be covered under warranty, don't void it by doing it yourself.
bigpow
Postby Guest » Fri Nov 14, 2003 5:08 pm
Found the rattle. It was the very edge of the headliner tapping the roof so I shoved a little bit of foam wrap in-between. Problem fixed. :D
Guest
Postby TW85 » Fri Nov 14, 2003 6:43 pm
Arg, I forgot that I had cleared all internet files. Anyway, that is my reply above.
TW85
