SolaraGuy.com • View topic - 10% Ethanol: Good, Bad, Neither?
Postby fotodad » Wed Nov 26, 2003 5:50 pm
One of the gas stations in my area sells all grades of its gasoline with a 10% additive of ethanol. Typically this station is one to two cents cheaper per gallon than everyone else. Is ethanol something that improves engine performance, a way to make gas a little cheaper, or something else in between?
2004 Solara SLE
Lunar Mist/Graphite
InvisaGuard
20% tinting all around
Michelin Pilot A/S
fotodad
Postby Guest » Wed Nov 26, 2003 9:38 pm
I have heard that it should be used once in a while to clean out your engine's fuel system etc. My friend's truck after filling up with it ran beautifully.
I'm guessing you might just want to use it every now and then given it's $$.
Guest
Postby Buckeyegirl » Thu Nov 27, 2003 5:40 am
Here's a site that will answer some of your questions.
www.ethanolrfa.org/factfic_enperf.html
Buckeyegirl
