SolaraGuy.com • View topic - Adding Automatic Climate Control to SE
Postby Hammerli » Mon Dec 01, 2003 6:50 pm
Has anyone investigated adding the climate control to an SE? I am hoping the harness is there, and it would simply require swapping modules. Anyone checked this out in the shop manual? I didn't think it would be a big deal, but I find I am always adjusting the fan and temp to stay comfortable.
2000 Celica GT-S 6 speed
2004 Solara SE Sport V6
Black Pearl Emblems
Blizzak WS-50 215/55/17
Hammerli
Postby mcinque103 » Mon Oct 06, 2008 8:30 am
i was wondering the same thing. this is the only post i could find in the search.
mcinque103
Postby Jakecallun20 » Mon Oct 06, 2008 9:49 am
I don't know about gen 2s but I do know that gen 1s have different plugs on the back
Postby kingkakyle » Mon Oct 06, 2008 10:32 am
u technically can do it
but it requires a lot of wiring which include temperature readings and such
the cost and time to do it is way too much to get any benefit
theres a couple threads on it, probably just have weird titles
Postby Black Bob » Mon Oct 06, 2008 12:36 pm
I'm assuming you're asking if it's a simple swap out, it's not. The air conditioning amplifier assembly right behind the control unit will be different. In fact, most of the connections are different between the 4-cylinder and the 6-cylinder even on the same model year. And like kingkakyle said, there's also the matter of adding the sensors to read the cabin temperature. (Caveat: No I'm not an expert I just read the mechanics manual after wondering about the exact same question.:wink:)
Black Bob
Postby mcinque103 » Tue Oct 07, 2008 9:02 am
i was hoping it would be as simple as changing the control unit. guess not. thanks for the info.
mcinque103
Users browsing this forum: Google [Bot] and 4 guests
