SolaraGuy.com • View topic - 18" Tires
18" Tires
18" Tires
Postby biggie » Sat Dec 06, 2003 11:37 am
I just purchased 18" Lexani Krystal wheels for my '04 Black SE V6 Sport. I understand the stock diameter of the 215/55R-17's is 26.4", but it is width that concerns me. The place I purchased the rims from and tirerack.com recommend 225/45-18's because of the neglegable decrease in diameter, but I want to put on as wide of a tire as possible and was possibly thinking of purchasing Pirelli 235/40ZR-18's. Rgache mentioned that putting 235/45R18's added .1" in diameter. Does anyone know how the diameter of a 235/40-18 compares to a 225/45-18? Also, would 235 width be too wide? I'm sorry if my questions sound ammateur, but this is the first time I will be changing my stock tires/rims. If anyone else out there with an '04 has 18's, what tires have you decided to go with and why? Your advice would be greatly appreciated.
2004 Solara SE V6 Sport:
Black/Black
18" Lexani Krystal Wheels
Xenon Lights
biggie
Postby biggie » Sat Dec 06, 2003 11:38 am
I forgot to mention that the width of the rims is 8".
Black/Black
Xenon Lights
biggie
Postby Jackass-Jeff » Sat Dec 06, 2003 11:50 am
i have 225 x 40 x 18 on my 18x8
1GR-FE ftw!
Jackass-Jeff
Postby biggie » Sat Dec 06, 2003 11:55 am
Don't those tires leave you with a nice-sized gap from your tire to wheelwell? And won't it throw off your speedometer? Do you have any pics of your ride?
Black/Black
Xenon Lights
biggie
Postby slingshot » Sat Dec 06, 2003 12:16 pm
Look at this website to calculate tire size effects on your car (speedometer changes,etc). It is an awesome website.
http://www.miata.net/garage/tirecalc.html
slingshot
Postby Jackass-Jeff » Sat Dec 06, 2003 12:53 pm
ill get some up soon. I'm working on a camera mount project right now =P probably tomorrow
18x8 offset +50 (offset brings the wheel closer to the strut, or pushes it out from the strut) but I'm on a 2002 so it may look different...
1GR-FE ftw!
Jackass-Jeff
Postby biggie » Sat Dec 06, 2003 1:10 pm
I checked the tire calculator and there is a .1% difference in a 235/45-18 from stock and a -1.3% difference in 225/45-18 from stock. Both sizes have pretty close to the same diameter as the stock 215/55-18's. Which size would be a better fit for my 18x8's and for the car? Would the 235/45-18's rub at all?
Black/Black
Xenon Lights
biggie
Postby Guest » Thu Dec 11, 2003 10:04 pm
pfff...18's look plenty big
Guest
Postby dabuda » Fri Dec 12, 2003 6:55 am
i'm thinking of getting 235/40/18 as well...more manufacturers make this spec tire so it's usually cheaper...anyone have these for any brand?
dabuda
