SolaraGuy.com • View topic - I Get Flashed the Brights A Lot.
Postby fotodad » Sun Dec 21, 2003 12:47 am
I've noticed on-coming traffic often flashes me the brights. I have factory low-beams in my 04 SLE. I have NOT tampered with how they are aimed. Only the brights have Silverstars. Since I drive on rather busy roads, I seldom use my high beams, but it seems if 20 cars go past me, one or two will flash their brights at me. I used to think it was because I had the fog lights turned on, so I turned them off. It made absolutely no difference. Has anyone else experienced this problem?
2004 Solara SLE
Lunar Mist/Graphite
InvisaGuard
20% tinting all around
Michelin Pilot A/S
fotodad
Postby Buckeyegirl » Sun Dec 21, 2003 6:13 am
I've never had this problem so far, have you ever put your car on a flat surface with your lights on against a building or a garage door to see how thier aimed? You gotta remember these cars were made in Kentucky, your car could have been at the portion of the assembly line where they aim the lights during a shift change. :lol:
Buckeyegirl
Postby JoeB » Sun Dec 21, 2003 7:13 am
I've had that problem with several new cars I've bought. I think car manufacturers purposefully aim them high. I usually aim them down a little myself. I don't think it is a big difference. I bet if you checked them, they would be just a little above the limit. -JoeB
JoeB
Postby Jackass-Jeff » Sun Dec 21, 2003 2:40 pm
THe projectors make the silverstarts more concentrated so it's almost like a HID beam shining at them =P I get the high beams a lot because I have HIDs in the halogen reflector housing hahaha
Future plans:
HID highbeams and fogs *evil grin*
1GR-FE ftw!
Jackass-Jeff
Postby TW85 » Sun Dec 21, 2003 5:00 pm
People often flash me too. I have done nothing to the headlights so it is a factory setting that people apparently think is too bright (high).
TW85
Postby Shoe » Sun Dec 21, 2003 8:18 pm
i kept getting flashed with this car buy some knob in an 98 - 02 accord 4 door he is comming home from work as im leaving at 6 am its still dark so after the 5th day i turned around followed him home i pointed teh car up his drive he went to bark at me i barked this is normal, stuck my hand in the car and pulled the hi beams on THESE ARE HIGH BEAMS good morning too you too !!!!
got in the car he hasnt done it since
Shoe
Shoe
Postby SportGuy » Tue Dec 23, 2003 6:48 pm
I have noticed the high beam flash occasionally. If you notice the light ahead of you from this car, there is a very distinct line that the lights cut out at the top of the view so I don't think the lights are mis-aligned. I believe these are high intensity and gives a brighter light which throws people off.
04 Solara SE Sport
Absolutely Red
Fast and Fun!!
SportGuy
Postby pantyninja » Fri Dec 26, 2003 8:36 am
Happens all the time to me too. I just flash em back to educate them. The regular beams definitely are very intense. An 04 Solara drove at me for the first time the other night and they are super bright. I think mostly it's becuase the beam is so focused unlike traditional headlamps.
Rejoice O Young Man in thy Youth
04 SE-V6 sport
Absolutely Red
pantyninja
Postby Jackass-Jeff » Fri Dec 26, 2003 11:17 am
It looks nice =D How high are the beams pointed when you are stopped behind another car? The 1.5s are aimed to be at trunk level and lower (gen 4 camry trunk) and if you're lowered... lol near the bumper =x
1GR-FE ftw!
Jackass-Jeff
Postby fotodad » Fri Dec 26, 2003 11:46 am
x rave xboix wrote:It looks nice =D How high are the beams pointed when you are stopped behind another car? The 1.5s are aimed to be at trunk level and lower (gen 4 camry trunk) and if you're lowered... lol near the bumper =x
x,
This seems like a good way to check the beam height. I'll check it out and get back to ya.
2004 Solara SLE
Lunar Mist/Graphite
InvisaGuard
Michelin Pilot A/S
fotodad
Postby Jackass-Jeff » Fri Dec 26, 2003 3:43 pm
my hid never bothered anyone til i was LOWERED... makes NO SENSE lol unless the reflectors glare up...
1GR-FE ftw!
Jackass-Jeff
Postby Pakin » Fri Dec 26, 2003 8:10 pm
Yes, during nights where I have guest in the car they always ask "are your highbeams on?". I think I've got 1 or 2 flashes so far, but the beam is indeed higher than most cars I've driven.
-paK +2
Pakin
Postby SportGuy » Sat Dec 27, 2003 8:32 pm
Seems to happen more when the fog lights are on or there are passengers in the car. Had several people flash me tonight.
04 Solara SE Sport
Absolutely Red
Fast and Fun!!
SportGuy
Postby glenb » Fri Jan 02, 2004 2:54 am
I get that also but only with the fog lights on.
glenb
Postby slingshot » Fri Jan 02, 2004 8:17 am
Hmmm, I drive with the fog lights on all the time and have never had the brights flashed to me yet.
slingshot
