SolaraGuy.com • View topic - Go for the TRD springs or wait for Tein dampers?
TRD springs
3
30%
Wait for Tein dampers (whenever/if they come out)
7
70%
Total votes : 10
Postby got sport » Sun Dec 28, 2003 3:35 am
Suggestions welcome...
<b>'04 V6 SE Sport -Black</b>
http://www.cardomain.com/id/gotsport
got sport
Postby Peter » Sun Dec 28, 2003 10:54 am
they're already out. another coil over set i suggest is the flta1's from JIC. they're a little cheaper and in my opinion better because the height adjustment on the JIC's lower the whole arm without compressing the spring so the ride quality isnt effected when you drop you car and it has an upper pillow mount for the front so u can adjust camber. the only downfall is that its only 5 way adjustable damper, but thats good enough for me. i just installed my set last week and im lovin them.
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby Jackass-Jeff » Sun Dec 28, 2003 11:53 am
Just think if you need adjustability in your ride. If not, then the Springs should do for now until new struts (stiffer) come out :D
1GR-FE ftw!
Jackass-Jeff
Postby dabuda » Wed Dec 31, 2003 8:31 am
i posted this question in the other suspension thread but won't the solara 'sport' suspension hold up with the TRD springs? as opposed to the regular non-sport solaras?
dabuda
Postby got sport » Wed Dec 31, 2003 10:20 am
That’s a good question theoretically, because if they do, then I will get the TRD springs.
It will be best to ask TRD themselves. I’ll contact them as well.
got sport
