SolaraGuy.com • View topic - anyone have the 4 cylinder?
Postby Snooters » Fri Feb 20, 2004 1:20 pm
i was just wondering how weak it's performance is. i really want a 6 cylinder but i'm stuck with the 4 since i want a stick shift. i'll be coming from a a 100hp saturn, so i was wondering what my expectations should be. i'll be test driving soon, just curious though.
if there are any obvious performance mods for the 4 cylinder i'd be interested in hearing about those too.
btw nice forum you got here...
Snooters
Postby Jackass-Jeff » Fri Feb 20, 2004 1:41 pm
I drove the 4-Cyl 04 Solara... I own a 02 4-Cyl Solara.
The increased weight of the 04 (200-300 lbs?) made the 4-cyl VERY sluggish compared to my 02 (same engine). It's not HORRIBLE, but if you can afford the V6, I'd tell you to get it.
Good luck (I don't think there are any 04 i4 owners for that reason I stated)
1GR-FE ftw!
Jackass-Jeff
Postby TadS » Fri Feb 20, 2004 3:47 pm
The 2AZ has a supercharger coming from what I have read. Other than that, I am not sure what’s going on with the platform. The word is the new Scion will have one, so that should increase aftermarket support for the motor :D.
On a side note I will probably try to get a 2005 w/2AZ-FE in August of 2005 (when my current car is paid off :D).
TadS
Postby krawzyazn » Fri Feb 20, 2004 5:53 pm
power toyota of cerritos has 2 v6 solaras brand new for 18,988 this weekend only
pretty cheap i'm thinking of tellin my parents to go buy it hahaha thne i can play with that car too
Postby kalibleek » Sun Feb 22, 2004 11:59 am
i just picked up one of the 4 cylinders over a month ago. i've had no problem with it...i had a 2004 honda accord coupe, also a 4 cylinder, for a month before that. the solara actually performs better then the accord did. of course, i did own a 2000 kia sportage before both of those...so anything's a step up from that :D
W.S.W.B.
257
fab 5
westside
kalibleek
Postby slingshot » Sun Feb 22, 2004 1:18 pm
I test drove the 4 cylinder before buying the 6 cylinder. The 4 cylinder is no slouch and I wouldn't call it slow but I preferred as much power as I could get.
slingshot
Postby Jackass-Jeff » Sun Feb 22, 2004 1:19 pm
slingshot wrote:I test drove the 4 cylinder before buying the 6 cylinder. The 4 cylinder is no slouch and I wouldn't call it slow but I preferred as much power as I could get.
i was comparing it to the same engine in a 200-300 lb lighter car, that's why it felt sluggish... maybe it isn't? =x
1GR-FE ftw!
Jackass-Jeff
Postby badjura » Mon Feb 23, 2004 9:03 pm
i was comparing it to the same engine in a 200-300 lb lighter car, that's why it felt sluggish... maybe it isn't? =x[/quote]
Your right - but the 04 didn't quite gain that much flab - The base 02 auto's from the factory are 3130lbs and the 04's are 3230lbs - add some stuff and your up there
2002 SE 2.4_TRD Kit - BBS
badjura
Postby Snooters » Mon Feb 23, 2004 10:14 pm
cool, thanks for the replies. i'll probably still get the 4 cylinder.
Snooters
Postby chuchurocket » Tue Feb 24, 2004 1:07 am
i have the 04 4cylinder
compare to my sister's 03 altima 2.5 and my friend's impreza rs, solara's 2.5 engine is really not as strong. but to me it's still worth the money, since all i do is daily commute, goto school, gym, pick up groccery and stuff. and don't worry it's not THAT slow, it's still a good engine, i have no trouble accelerating to a certain speed within expected time interval. not to mention the cost and mileage you save
chuchurocket
Postby Jackass-Jeff » Tue Feb 24, 2004 8:11 am
chuchurocket wrote:i have the 04 4cylinder
The Solara is 2.4 =P You were expecting too much from it =D
1GR-FE ftw!
Jackass-Jeff
Postby krawzyazn » Tue Feb 24, 2004 11:22 am
Snooters wrote:cool, thanks for the replies. i'll probably still get the 4 cylinder.
hey man if you can get the 6 get it like i said toyota of cerritos had it for $18,988 brand new
Postby Snooters » Fri Feb 27, 2004 10:26 pm
i noticed that. cerritos rang a bell, i'm from that area.
i'm also paying attention to the scion tC. it comes with an optional 200hp engine with stick shift. i saw it a the la auto show but it looked really small. the solara definitely wins in the looks dept. it really reminds me of that lexus coupe...
my exclusive crappy pic of the tc:
Snooters
