SolaraGuy.com • View topic - Gas Fill Door Release Lever
Postby TW85 » Thu Apr 15, 2004 9:25 pm
The release lever inside the car (near trunk release) for the gas door sticks in the open position each time I pull it up. It will not automatically return to its "down" position. I have removed the plastic cover several times and tried to bend the lever a little to the left but it always reverts back to the original position. Do any of you have the same problem?
Moved on to better things...
TW85
Postby pantyninja » Fri Apr 16, 2004 6:53 am
I have not had that problem. If I were you I would definitely bring it in to the dealer rather than trying to bend anything into position. They should tak care of it for you. Best of luck
Rejoice O Young Man in thy Youth
04 SE-V6 sport
Absolutely Red
pantyninja
Postby NOBOOST » Fri Apr 16, 2004 7:17 am
My jetta had a similar problem with a twist... the fuel release was electronic with NO MANUAL RELEASE at all... It went bad 3 times and once required a tow because I ran out of gas... anyway
Take it to the dealer because there may be something stuck in the line somewhere... maybe take a quick look near the gas cap to see if that is where the problem is?
NOBOOST
Postby Jai_Jai_Binks » Fri Apr 16, 2004 8:11 am
My camry (gen 4) had a problem where i'd pull the remote lock (by the trunk popper) and nothing would happen...Later i learnt that there was a TSB for my year camry...and the dealer installed a new thing (that I was also twisting to make it pop right initially). TSB solved my problem.....
Users browsing this forum: Google [Bot] and 14 guests
