SolaraGuy.com • View topic - DVD Navigation Option
Postby ShouldIbuyaSolara » Fri May 14, 2004 4:09 pm
I'm trying to get a clear understanding of the Toyota DVD Navigation option for the Solara but the salespeople seem to be lacking in sales info/training.
Specifically
1: Does it come with or allow for a camera to be hooked up
2: Does anyone that has one like it or not and why
3: Do you think it's better than GPS
4: Is it comprehensive and easy to use
ShouldIbuyaSolara
ShouldIbuyaSolara
Postby LunarMistGray » Fri May 14, 2004 4:35 pm
1) No, it does not come w/camera like the Infiniti FX45 and I doubt you can connect a camera.
2) I like the Navi. It's nice and easy to use and accurate for me. You do have to read the instructions, but once you do you'll love it.
3) It uses GPS.
4) For me yes, but I'm pretty sure there will be some that say it's not accurate or it's difficult to use.
I hope this helps.
2004 Solara SLE V6 with NAV
Lunar Mist Metallic/Graphite
TRD Lowering Springs
TRD Rear Sway Bar
LunarMistGray
Postby ShouldIbuyaSolara » Fri May 14, 2004 4:58 pm
Wouldn't you know it those salespeople led me to believe it was not GPS, simply displayed a map from a DVD. Do you know if this unit is made by Garmin or Magellan or some other company? At one time I almost purchased a Garmin.
ShouldIbuyaSolara
ShouldIbuyaSolara
Postby slingshot » Fri May 14, 2004 5:31 pm
It uses both a DVD and GPS. I forget the name of the company but it isn't Garmin or Magellan.
slingshot
Postby erasat » Fri May 14, 2004 6:05 pm
Check this Auction out, and also the seller website at www.oemvalue.com, I think is one of the best info you will find about this Navigation system from toyota.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WDVW
erasat
Postby seany » Fri Oct 01, 2004 10:45 am
Back-up CAMERA...
Yes, there is a back-up camera by Eclipse (model #BEC103) which is a simply plug&play which I have in my Sienna plugged into my 2004 Solara NAV (yes, I have solara nav in my sienna).
Eclipse is by Fujitsu-Ten who makes the Solara NAV unit.
2004 Sienna XLE AWD
Add-Ons : '07 Solara Navigation with Voice Command/Bluetooth & Eclipse Reverse Camera
seany
Re: DVD Navigation Option
Postby jsie » Fri Oct 01, 2004 2:05 pm
ShouldIbuyaSolara wrote:3: Do you think it's better than GPS
I do not have Navigation, but I am familiar with it. Answering your question #3, the OEM navigation is utilizing the GPS technology together with the mapping comes in the DVD disk as well as utilizing your vehicle sensors. If you are reffering to compare with the stand alone GPS sold in electronic stores, my opinion is "yes" the OEM Navigation is better as I would say it gives better responsiveness to the direction as you are driving. Additionally the DVD gives extensive US map and easy to upgrade with newer map by just getting the newer DVD disk when newer revision is out.
2004 Solara SE Sport
Artic Frost Pearl
2.4L I4 5-Speed MT
jsie
Postby seany » Mon Oct 04, 2004 11:57 am
Just to further elaborate, all of Navigation systems use GPS technology, how else???
The map DVD contains the software to operate the NAV unit and the big database of map (street names, city, POI, phone #, etc.) of 48 US states & Canada so the NAV unit can display the map on the display.
The NAV uses it's GPS antenna to receive GPS satellite signals to figure out where you are on that map.
The major difference between one of those integrated (wired) NAV and the stand-alone handheld NAV units is the integrations :o with the car's speed sensor and the back-up sensor. So when the NAV loses it's GPS satellite signals, it still can, somewhat, figure out that you're moiving but this alone won't be very accurate once you're making turns.
2004 Sienna XLE AWD
seany
