SolaraGuy.com • View topic - Looking for 12v hot with door open
Postby Animal » Wed Jun 09, 2004 2:25 pm
Anyone know which wires at the kickpanel are hot when the door is open? Also, if you know which are hot when the motor is running, and all the time hot? Any alternatives to the kick panel for wiring accessories like radar detectors and interior lights?
Thx
2004 Solara SE V6 Sport Coupe
Black/Black
35% tint
Partially debadged
http://members.cardomain.com/04solara
Animal
Re: Looking for 12v hot with door open
Postby Blazed04 » Thu Jun 10, 2004 2:00 pm
Animal wrote:Any alternatives to the kick panel for wiring accessories like radar detectors and interior lights?
Umm...off the battery to a switch :o
Lunar Mist '04 SE Sport V6
2001 GSXR 750
Blazed04
Postby bassthrive » Mon Jun 14, 2004 8:55 pm
Hot when open? Not that I could find. There is however a ground when the door is open. Scroll down to step three here. If you connect a constant 12 volt (heat seater fuse, cig lighter fuse...) to one side of your accessory, then splice the ground into the red wire with white stripe, you'll be in business. PM me if you have any questions.
<<< EDIT - just noticed you have a 2004, these instructions are for a 1st gen and i dunno how much toyota changed the wiring. Get in there with a test light and poke around for a wire that behaves how you want it to, thats how I found the ground in the first place. >>>
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
