SolaraGuy.com • View topic - do you notice when you floor it?
Re: do you notice when you floor it?
Postby michaels artic frost » Mon Jun 21, 2004 1:54 pm
Kung Fighting Dude wrote:today the traffic was crazy, so I decided to floor it to get away from all the bs. when I put the pedal to the metal, I notice it took like two seconds for the full acceleration power to come on, is it lag?
I drive a gen 2 solara I4
Hey, I noticed that once before as well. But hasn't happened since then. Maybe it was the gas that I had gotten. It's been fine since I've been going to the same gas station. Perhaps when I was out of town and had to get gas at another gas station. Oh well...
Updated 06/01/12: Michael T's
Postby Gyaf » Mon Jun 21, 2004 2:21 pm
sometimes ive noticed a slight lag before you get your speedburst yeah...
when i'm in a situation where i'm jumping in like that, sometimes i'll go to the auto-stick thing and downshift into 3rd for a bit of a boost
Gyaf
Postby Shoe » Mon Jun 21, 2004 3:43 pm
was your ac on?
shoe
Shoe
Postby geminimouse » Mon Jun 21, 2004 4:43 pm
the Auto lag :P
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby TW85 » Mon Jun 21, 2004 5:36 pm
Two things cause it: 1) automatic transmission 2) throttle-by-wire. It is mostly #1.
You can reduce the delay by shifting down 1 or 2 gears using the sportshift mode.
Moved on to better things...
TW85
Postby Jewls » Tue Jun 22, 2004 4:49 am
Mine does the same thing, drives me nuts because I am an aggressive driver. :evilbat:
2005 Mustang GT Premium
2004 SE Black-SOLD
Pioneer MP3/XM radio/speakers,K&N filters,TRD RSB,Cargo Net,OEM Mud Guards,sport pedals, blue interior lighting,TRD oil cap,20% tint
Jewls
Postby michaels artic frost » Tue Jun 22, 2004 5:37 am
Jewls wrote:Mine does the same thing, drives me nuts because I am an aggressive driver. :evilbat:
MOVE OUT THE WAY GUYS!!! JEWLS on da road...lol...jk. :D
Postby 04solarafanatic » Tue Jun 22, 2004 6:45 am
Hey guys...i noticed the same lag....I was reading in the manual and it said that the throttle is not controlled by a wire like the previous models....rather the throttle is controlled digitally now.
I guess that can cause the lag...maybe takes time for it to register before the car realises that you put the pedal to the medal.
Also...is it bad for the car if you downshift alot into sports mode?
I been wanting to use sports mode....but Im waiting til I break 3k miles...then I will mess around with it..in an empty parking lot...hehehe
Well...hope that helps....correct me if Im wrong...but I'm pretty sure I read that in the manual one day when I was really bored.....
04solarafanatic
Lag
Postby glenb » Wed Jun 23, 2004 9:31 am
I noticed a lag from time to time. My thought is, it is the computer on the throttle-by-wire. This is one thing that Toyota should address. Has anyone contacted Toyota?
2004 SLE V6
Desert Sand Mica/Ivory
glenb
Postby hari-bhari » Wed Jun 23, 2004 10:57 am
that lag you notice is your a/t downshifting into a lower gear to get into a higher powerband, hence giving you more power. but it takes time to shift.
hari-bhari
Postby angelo » Wed Jun 23, 2004 1:50 pm
04solarafanatic wrote:Hey guys...i noticed the same lag....I was reading in the manual and it said that the throttle is not controlled by a wire like the previous models....rather the throttle is controlled digitally now.
Actually the fact that the trottle is controlled digitally should make the trottle response faster, maybe the downshift is causing the delay...
angelo
Postby TW85 » Wed Jun 23, 2004 4:52 pm
It is not just the downshift creating the delay. There is sometimes a noticeable delay before the transmission even shifts to a lower gear.
TW85
Postby Prophet » Wed Jun 23, 2004 4:56 pm
For whatever it's worth, the lag is found in any Toyota or Lexus which shares the same engine as the Solara and I believe in another Toyota engine as well that was used in earlier Camrys.
Our RX300 has the same lag, same engine...and I remember reading a list of Toyota/Lexus vehicles with the same lag on the net somewhere while researching the Solara.
2004 Solara SLE
Oceanus Pearl
Prophet
