SolaraGuy.com • View topic - Ticking Noise???????
Postby Jewls » Mon Jun 28, 2004 7:57 am
Ok when my car is running, you can hear this constant ticking sound. The dealer says that this is caused by the hydraulic lifters, and that this is totally normal, but never heard that noise when I was in other 04's. Anyone else hear it?
2005 Mustang GT Premium
2004 SE Black-SOLD
Pioneer MP3/XM radio/speakers,K&N filters,TRD RSB,Cargo Net,OEM Mud Guards,sport pedals, blue interior lighting,TRD oil cap,20% tint
Jewls
Postby Jackass-Jeff » Mon Jun 28, 2004 8:14 am
It's normal...
1GR-FE ftw!
Jackass-Jeff
Postby Jaimster » Mon Jun 28, 2004 3:02 pm
Normal, many cars tick after you turn it off! That's metal cooling down you hear or heating up as well.
Jaimster
Postby Gyaf » Mon Jun 28, 2004 4:47 pm
i dont hear mine tick, either inside, or outside w/ the car on.
Gyaf
Postby Jackass-Jeff » Mon Jun 28, 2004 6:01 pm
you'll eventually hear it tick...
1GR-FE ftw!
Jackass-Jeff
Postby Jewls » Tue Jun 29, 2004 4:18 am
Well, got the car back. They swear that the ticking is normal for the type of motor and the lifters. As far as the left drift, my VIN# came after they made the fix on the line, so they say my alignment was WAY off from the factory, and that it is now fixed. It still pulls to the left a little, but nowhere near as much as it did before. :-?
2004 SE Black-SOLD
Jewls
hmm
Postby solaramodxtreme » Thu Jul 01, 2004 7:22 pm
what u have heat is a tsb (technical service bulletin) if the tech did an alignment what he did was pull ur tires to the right alot. :agrue: ...the real thing to do is tell them to check the tsb's and they gonna see they have to order big camber bolts from japan and install them till then it wont be fixed no matter what u do :drinking:
4 banger
solaramodxtreme
Postby xodessitx » Fri Jul 02, 2004 12:22 am
can u plz explain to me what exactly did u mean by the tsb and the parts to be ordered. i took my car twice to fic the left drift, and now it pulls to the right with the steerin wheel always tilted to the left. the dealer tells me he dosent know what the problem is. can you plz explain it to me.
thanks
2004 solara
se sport v6
lunar mist
getting tints probably 20% all around
more coming soon.....
xodessitx
Postby michaels artic frost » Fri Jul 02, 2004 4:31 am
xodessitx wrote:can u plz explain to me what exactly did u mean by the tsb and the parts to be ordered. i took my car twice to fic the left drift, and now it pulls to the right with the steerin wheel always tilted to the left. the dealer tells me he dosent know what the problem is. can you plz explain it to me.
thanks
The dealer is giving you a buncha BS. He knows exactly what you're talking about. It took them 3 tries to fix mine. Take it back. I just hate going to the dealership for service.
GL.
:evilbat:
Updated 06/01/12: Michael T's
Postby Jewls » Fri Jul 02, 2004 7:00 am
Well, my VIN# comes after the ones listed for the TSB. They said my alignment was just way off. It still pulls to the left a little, but nowhere near what it used to. I used to have to hold the wheel at 1 o clock!!!
2004 SE Black-SOLD
Jewls
Postby michaels artic frost » Fri Jul 02, 2004 7:12 am
Jewls wrote:Well, my VIN# comes after the ones listed for the TSB. They said my alignment was just way off. It still pulls to the left a little, but nowhere near what it used to. I used to have to hold the wheel at 1 o clock!!!
Still not fixed huh? How many times has it been in the shop? Make them fix it! It just get's so annoying when I take my hand off the steerring wheel, it starts to pull to the left. You'll feel better once it's fixed, I know I did. :)
Postby onefiend » Fri Jul 02, 2004 9:35 am
Gyaf wrote:i dont hear mine tick, either inside, or outside w/ the car on.
dont worry you will...happened to all of us who's bought a car thats new. It sound slike a fast ticking time bomb and you'll hear it when the car is off....then after sometime the ticking goes away.
onefiend
Postby Jewls » Fri Jul 02, 2004 10:45 am
I hear the ticking when the car is running????
2004 SE Black-SOLD
Jewls
Postby michaels artic frost » Fri Jul 02, 2004 10:49 am
Jewls wrote:I hear the ticking when the car is running????
The dealer said it was hydraulic lifters... If that's the case, my old ride '95 MX-3 it was ticking and it had lots of miles on it and they told me it needed to be clean and that's the reason for the noise. If it's the same noise that we're refering to. The ticking noise only occurred while the car was running.
I'm not hearing any noise on mine, but I'm going to double check while it's in the garage and see if I can hear anything.
