SolaraGuy.com • View topic - question about PSI
question about PSI
question about PSI
Postby StockSolara » Thu Aug 12, 2004 5:33 pm
I'm planning to buying a supercharger pretty soon and I wanna upgrade the pulley and I was wondering what is a safe PSI to up to with out damaging the auto tranny if i get an automatic tranny cooler?
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Mole » Thu Aug 12, 2004 6:23 pm
i say 5.5psi. your trans will be able to handle more, its just the engine's side that is the make or break factor.
run with stock first. upgrade fuel delivery, then think about upgrading the pulley.
Postby Hsakuragi » Thu Aug 12, 2004 10:00 pm
if 5.5 safc is a must!
Hsakuragi
Postby Fletch » Fri Aug 13, 2004 10:07 am
I don't have the safc or any fuel upgrades and I am okay.
2006 Legacy GT spec.B
Fletch
Postby Mole » Fri Aug 13, 2004 10:47 am
you are most likely running fairly lean.
Postby SC V6 » Fri Aug 13, 2004 11:20 am
indeed.. im scared to put the 7 back on, and I have a S-afc II, low compression heads, supra injectors, and the Walbro 190lph fuel pump
SC V6
Postby Astro » Fri Aug 13, 2004 4:12 pm
SC V6 wrote:indeed.. im scared to put the 7 back on, and I have a S-afc II, low compression heads, supra injectors, and the Walbro 190lph fuel pump
Did you ever get Jim's fuel kit, with bigger fuel filter and bigger lines to the rails? I'm considering going to 5.5 with just that, along with 100/91 octane mix.
Postby SC V6 » Fri Aug 13, 2004 4:24 pm
well I am going to order that on monday.. Jim's out of town... after that I think if I get to the dyno and get that tuned in ill be good
SC V6
Postby JoeB » Sat Aug 14, 2004 6:03 am
I would also STRONGLY consider the fuel regulator mod. It's free and it made up most of the difference in the imballance of fuel delivery between the front and rear rails. I did that mod first and measured the results. The fuel filter and lines are still a good idea, they correct the volume issue. -JoeB
JoeB
Postby SC V6 » Sat Aug 14, 2004 8:26 am
I already did the fuel reg. mod
SC V6
Postby cdssolara » Mon Aug 16, 2004 10:26 pm
Scott,
You should be fine with all the mods you have. You have almost the exact same set-up that I have, especially now that you've converted to a manual tranny. I kept getting the CE light for knock sensor #1, although the tuning shop that I've been working with didn't feel like any knock was occurring. I finally came to the conclusion that it was just an overly sensitive knock sensor, and had the knock sensor input to the ECU rewired so that sensor #2 feeds both signals. Voila, no more problems.
cdssolara
Postby StockSolara » Tue Aug 17, 2004 9:06 am
Thanks you all your inputs I guess I'll go with the 5.5 psi pulley
2000 Lexus GS400
StockSolara
Postby Hsakuragi » Tue Aug 17, 2004 10:14 am
come to the meet and i can show u mine
Hsakuragi
Return to Forced Induction
Users browsing this forum: No registered users and 102 guests
