SolaraGuy.com • View topic - rough start the other day...
Postby DavPak » Sat Aug 28, 2004 5:56 am
has anyone else ever had a rough start after letting the car sit for a while? this happened to me twice. the first time, the car had sat for 4-5 days without being driven and more recently sat for 11 days while i was on vacation. when i started it up, i got a low rumble that i could feel in the floor and steering wheel. this lasted for about 5 seconds. then it lessened to a minor vibration for about 15 seconds, then it went away completely!
i immediately thought my air filter wasn't on all the way, but i popped the hood and it looked fine.
eh, its no biggie, i was just curious if anyone else had that problem.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby xtychx » Sat Aug 28, 2004 11:16 am
Sounds like the ECU is attempting to clear an error code for some reason, but it could be a variety of problems. Off the top of my head, broken PCV, faulty air fuel sensor, faulty IAC valve or a broken EGR valve.
-xtychx
TRD Supercharger @ 7 lbs – JP Headers - Injen CAI – 3” catback to Hayame XT2 exhaust – 320cc bosch fuel injectors – 190 lph walbro fuel pump – SS FTC Fuel Management – B&M Transmission Cooler
xtychx
Postby Yanks0114 » Sat Aug 28, 2004 11:48 am
I don't think that its a problem.
Were the RPMs real low? Sounds similar to when you reset your ECU and it needs to relearn a/f ratio, it'll idle real low
Postby DavPak » Sun Aug 29, 2004 12:20 pm
Yanks0114 wrote:I don't think that its a problem.
i don't think its a problem either. RPM's were low at first, then came up gradually. check engine light never came on.
whatever, its no biggie.
DavPak
Postby shidosha01 » Sun Aug 29, 2004 6:34 pm
No worries Dave. Same thing happened to me the other day. I had my car sitting in the shop for almost two weeks with the negative terminal of the battery disconnected. I was freaking out about the RPMs getting real low at idle. But now "white chocolate" is fine.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Return to Forced Induction
Users browsing this forum: No registered users and 278 guests
