SolaraGuy.com • View topic - bent pulley
bent pulley
bent pulley
Postby TRD MCV20L » Wed Oct 20, 2004 8:15 pm
how hard is it to fix a bent pulley on the s/c? can it just be replaced? about how much would it be to get it fixed or would it be better to get a new s/c? thanks in advance.
TRD MCV20L
Postby ChargedSolara » Wed Oct 20, 2004 8:17 pm
do you mean the pulley that connects to the drive belt? because that is able to replace with just the part..if thats the case try searching under URD or pulleyboys.com, thats where i got my new pulley.
by the way, do you know why it was bent?
2008 C6 LS3
ChargedSolara
Postby TRD MCV20L » Wed Oct 20, 2004 8:29 pm
its the pulley connected where the s/c replaces the intake manifold. its the outer rim of the pulley that is bent. it was probably dropped. it spins good though.
TRD MCV20L
Postby Mole » Wed Oct 20, 2004 8:54 pm
good chance to upgrade pulleys.
Return to Forced Induction
