SolaraGuy.com • View topic - Looking for a bolt for the supercharger...
Postby wiz2 » Tue Dec 14, 2004 11:42 am
Does anyone know where I can get another supercharger bolt that connects the mounting plate and goes through the alternator ??
It's counter sunk 10mm x 1.25 x 100mm with a fitting for a 6mm hex wrench.
06 DG G35 Sedan 6 MT
motordybe spacer|stillen tube|MRR GT 1 19x8.5,19x9.5 Toyo T1R's
wiz2
Postby Akfahad » Wed Dec 15, 2004 10:20 am
yeah man, i had the same problem...the guy i bought my supercharger from accidentally forgot to send me the bolt, so i was frantically trying to find a replacement. Fortunately, however, he found it and shipped it to me. What i did, before i got the bolt, i found a specialty nuts and bolts store and they were in the process of ordering it. see if you can find one of those places, if not, try contacting TRD. Best i can do for you. By the way, the shop i used was "Fasnal." Don't know if it's just a local shop tho. josh
Postby Jai_Jai_Binks » Wed Dec 15, 2004 3:14 pm
Go to your local dealership, and look at the pictures to determine which bolt it exactly is and get a toyota part number. Then hit up eddie!
Postby wiz2 » Wed Dec 15, 2004 8:36 pm
Thanks Akfahad. I contacted a local Fastenal distributor. They have more bolts and stuff than I imagined. I'm going by one of thier stores this weekend to make sure its the right one,then I'll order it and have it in a day or two. They have already given me a part # .
If this works out i'll pass the info on.
Everybody knows the Toyota and TRD dont actually make bolts and nuts...right.
I also checked ARP.,but I think Fastenal has whats needed.
wiz2
Postby Akfahad » Fri Dec 17, 2004 7:47 pm
glad i could help
Re: Looking for a bolt for the supercharger...
Postby Gadget » Sun Jan 23, 2005 9:16 am
wiz2 wrote:Does anyone know where I can get another supercharger bolt that connects the mounting plate and goes through the alternator ??
Every single part that comes in any of TRDs supercharger kits has an individual part number. If you look at the installation guide that came with your supercharger you should be able to find the part number any part you need. Then you can order that part from your local Toyota dealer and wait a couple of weeks for it.
For those few part that you might need that are not properly listed with a part number you can call TRD and they should be able to look it up for you and then you can order it from your local dealer.
Gadget
Gadget
Postby Vampire » Sun Jan 23, 2005 11:43 am
Mine was seized because I forgot to put anti-seize compound on there when I did my first SC install. TRD or you Toyota dealer has the part as Gadget said just make sure you have the part number if you go to the dealer. My invoice listed the cost as $1.75 which was amazingly cheap considering it came from TRD but this was 3 years ago. I'm sure they raised the price but they do have the part. Good luck.
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Return to Forced Induction
Users browsing this forum: No registered users and 253 guests
