SolaraGuy.com • View topic - just dynoed 273.8whp and 282tq to the wheels!
Postby trd4life » Wed Dec 22, 2004 5:22 pm
Wow just got back from the dyno for the first time ever. I am happy with the results considering i havent done the headers or heads yet. Something was wrong with the vacuum hoses and the boost actuator was not working right. We got it settled and i picked up 70tq at 3000rpms, apparently i had installed the vacuum hoses wrong when i put the charger on. :o
I will upload the graph a little later.
what do you guys think?
Postby Paladin06Greg » Wed Dec 22, 2004 8:17 pm
:-? Wow I must say that's suspect without any internal work being done. I don't think it's possible!! :-?
Paladin06Greg
Torqued Solara
Torqued Solara
yeah it is...
Postby trd4life » Wed Dec 22, 2004 9:30 pm
my stock engine has 110,000 miles on it and i have been boosting 7psi for 20,000 miles. I run a mixture of xylene in my gas tank all the time. :D
i didnt come on here make up stories i just wanted to post results so everybody can compare to their cars.
Re: yeah it is...
Postby Paladin06Greg » Wed Dec 22, 2004 9:51 pm
Hey I'm not saying you're not telling the truth. I'm just amazed.
Please understand that I am excited about your numbers for sure..
trd4life wrote:my stock engine has 110,000 miles on it and i have been boosting 7psi for 20,000 miles. I run a mixture of xylene in my gas tank all the time. :D
Paladin06Greg
Torqued Solara
Torqued Solara
Postby wiz2 » Wed Dec 22, 2004 10:03 pm
Sounds good man. Your using a Fields vs. a SAFC for fuel control ??
Numbers are on target for a manual tranny. Same ballpark at Ericsol and others w/ similar set ups. Especially in that crisp cold New England air! I turned 238 whp in 90 degree heat. Another 38 whp with the additiaonal mods is reasonable. That torque is pretty fay too. Only guy I can think of still pushing 7 psi on stock internals.
Any of your 1/4 mile tracks still open ?? I'd love to see your new times.
Keep it up Gabe... I'll be copying er uh... I mean watching as your set up evolves. :lol:
06 DG G35 Sedan 6 MT
motordybe spacer|stillen tube|MRR GT 1 19x8.5,19x9.5 Toyo T1R's
wiz2
Postby Hsakuragi » Wed Dec 22, 2004 10:47 pm
u liar!! haha j/k :drinking: :drinking:
well tell us what's in ur baby while dyno..
good job...
Hsakuragi
Postby Fletch » Thu Dec 23, 2004 4:56 am
Congratulations on the results.
Did you use the intake air/fuel cooler system during the runs?
Hope that 7psi isn't too much for the internals...
2006 Legacy GT spec.B
Fletch
cryo2
Postby trd4life » Thu Dec 23, 2004 5:16 am
yeah i did use the DEI cryo2 setup during the last run and it kmade no difference :( i think the motor may have been heat soaked anyway.
i am still running the cat on my car and am tuned to 10.5:1 air fuel , the tuner told me take off the cat, he will tune to 12.0:1 and i will pick up another 10whp. :o
dyno sheet
Postby trd4life » Thu Dec 23, 2004 5:26 am
Postby JoeB » Thu Dec 23, 2004 6:04 am
Gabe, very impressive numbers! Not surprising as fast as your car is! Have you ever had it on a Dyno Jet dyno? I'm curious how it would compare. Different dynos always read differently. Did that one correct for temp, altitude, humidity, weight etc.? Also, out of curiousity, where was your car manufactured? Any chance yours was manufactured in Japan like Doug's? -JoeB
JoeB
cat?
Postby Fletch » Thu Dec 23, 2004 7:19 am
i am still running the cat on my car and am tuned to 10.5:1 air fuel , the tuner told me take on the cat, he will tune to 12.0:1 and i will pick up another 10whp.
Gabe,
I don't understand what you are saying about the cat. Please explain.
Fletch
Postby Hsakuragi » Thu Dec 23, 2004 9:31 am
JoeB wrote: Have you ever had it on a Dyno Jet dyno? I'm curious how it would compare. Different dynos always read differently.
Exactly, my car was on dyno jet and my number was very low, but of cuz, compare to your mod, mine is just the beginning....good job~ :)
Hsakuragi
cat converter
Postby trd4life » Thu Dec 23, 2004 12:40 pm
Fletch, i mean i am still running a catalayic converter, i am going ot take it off and put on a test pipe.
JoeB. i assume the dyno they used does correct for all of those factors. My car is not a JDM version like Doug's
Postby GReddySetGO » Thu Dec 23, 2004 12:57 pm
So you ditched the NOS when you got the SC setup?
Danny
AIM: GReddy EVO Si
Forced Fed @ 20 psi
GReddySetGO
nos
Postby trd4life » Thu Dec 23, 2004 1:35 pm
yeah when i picked up the charger i sold the nos kit to a local camry guy who put it on a 1mz automatic camry
Return to Forced Induction
Users browsing this forum: No registered users and 253 guests
