SolaraGuy.com • View topic - Dissapointed Dyno Numbers
Postby Yanks0114 » Sun Jan 02, 2005 5:32 pm
I got my car dynoed a week ago and i was very dissapointed by the numbers. I have a 2001 v6 with TRD s/c @ 4psi, apexi exhaust, and KN filter
I'll scan the graphs soon but my best run was 195FWHP and 175tq
I did blow a knock sensor at the dyno so i wonder if that affected performance. I expected to break 200FWHP
I was the first toyota the place i went to had ever done. They specialize in chevy and ford vehicles. They did give me respect for my car but i wish i could have broked 200hp.
The car was run in 3rd gear btw
...scans soon
Postby 209solara » Sun Jan 02, 2005 6:27 pm
wow, thats surprising. :o do you have upgraded plugs or wires?
209solara
Postby Mole » Sun Jan 02, 2005 6:31 pm
you need a Y pipe dude.
Postby Dawgz » Sun Jan 02, 2005 6:41 pm
isnt the stock v6 solara 200hp and 217 torque?
Postby Yanks0114 » Sun Jan 02, 2005 7:40 pm
Dawgz wrote:isnt the stock v6 solara 200hp and 217 torque?
Its 200hp and 212tq but thats at the crank
My numbers are at the wheels
The huge limiting factor is the auto tranny. I'd estimate drivetrain loss to be 25%+
HP isn't that far off from my goal, but from the other dyno results my tq is very low which is why i think my knock sensor may have been shot on the first run
I have upgraded plugs (IK22s)
I'm pretty much decided i'm done with performance mods for the car unless i can get a really good deal.
Postby Hsakuragi » Mon Jan 03, 2005 9:48 am
i assume u don't have the safc huh
Hsakuragi
Postby thakidd » Mon Jan 03, 2005 1:32 pm
jims fuel upgrade is all u need...........
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Postby Yanks0114 » Mon Jan 03, 2005 4:22 pm
hsakuragi wrote:i assume u don't have the safc huh
No SAFC.
I am not running lean so i'm not sure where the fuel upgrades come into place unless i wanted to run high boost.
I think i'm done with performance for a while on this car
Postby BustaRice » Wed Jan 05, 2005 11:51 pm
i got 181whp at the wheels and all i have is CAI and 4psi s/c. so with proper tuning of a safc i'd say you can break the 200 very easily.
i have a 98 auto also.
BustaRice
Postby Hsakuragi » Thu Jan 06, 2005 1:02 am
BustaRice wrote:i got 181whp at the wheels and all i have is CAI and 4psi s/c. so with proper tuning of a safc i'd say you can break the 200 very easily.
Not really that easy..my car dynoed barely reached 200whp with 5.5 and safc
i assume u have a camry :)
Hsakuragi
Re: Dissapointed Dyno Numbers
Postby shidosha01 » Thu Jan 06, 2005 6:23 am
Yanks0114 wrote:I got my car dynoed a week ago and i was very dissapointed by the numbers. I have a 2001 v6 with TRD s/c @ 4psi, apexi exhaust, and KN filter
...scans soon
Those numbers are just about right for an automatic s/c Camry Solara. Those are still good numbers. Congrats. Maybe an intake and SAFC II will help you break your goal of 200 WHP.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby ToyCam » Thu Jan 06, 2005 1:50 pm
Hey Yanks, I feel ya man. I dyno'd my car years ago and couldn't break 190 let alone 200 :drinking: Unfortunately, based on what I've seen, the lower than expected HP results are typical. However, your TQ numbers do look off quite a bit.
Here's my chart. My only mod is an SAFC-I.
http://www.imagestation.com/picture/sra ... 76c1dc.jpg (copy and paste URL)
Here's another person's charts with an SAFC-I aswell. It took them 5 runs to break 200.
Time to dial up the fuel :evilbat:
'92, '99, '02 V6 Camrys. Guess which one is SC'd
ToyotaNation.com
ToyCam
Hey
Postby mmcdonald » Fri Jan 07, 2005 5:43 am
Did you retard the timing enough for the boost? With boost you need to do a little retarding, oddly enough, to gain HP. It sounds like your knock sensor was not able to do enough retarding for the boost. This would definitely effect power output.
2004 Solara SE Sport V6 Black
DocJohn's Vacuum Trick
K&N AF, Removed Secondary AF
XM Tuner DIY
mmcdonald
Postby Mandarinsolara » Thu Jan 13, 2005 10:14 pm
octane?
Mandarinsolara
Postby TRDCamry » Fri Jan 14, 2005 10:06 am
I have just about everything you have on your Camry, except I have a plamsa booster and a tuned safc and I got 206 to the wheels.
Here's a link for info and pics of my 1999 Camry:
http://www.toyotanation.com/forum/t44068.html
Sohil
TRDCamry
Return to Forced Induction
