SolaraGuy.com • View topic - Blown head gasket! Time for a rebuild
Postby trd4life » Sat Jan 22, 2005 9:12 am
Well as most of you know i have pounded on my car for years now using nitrous and then a TRD supercharger at 7psi on stock internals. At 111,000 she finally let go. I went to check my oil this morning and it was creamy foamy looking. I assume its a head gasket. Time for a rebuild. Can you guys point me in the right direction on where to order pistons, rods, and head studs. thanks
Postby 209solara » Sat Jan 22, 2005 10:11 am
tough break, we all knew it would happen eventually. good luck with the rebuild.
209solara
Postby SC V6 » Sat Jan 22, 2005 12:20 pm
sounds like you blew piston lands 2... I bet its not the head gasket at all.. rather blown lands... good luck
SC V6
Postby Paladin06Greg » Sat Jan 22, 2005 12:39 pm
:( Well I knew it wouldn't be long. You're lucky she held together as long as it did.
Now if you want rock solid monster motor contact ArrietaMotorSports.com..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Hsakuragi » Sat Jan 22, 2005 5:00 pm
at least u have the numbers before she's gone :)
Hsakuragi
Re: Blown head gasket! Time for a rebuild
Postby JoeB » Sat Jan 22, 2005 9:23 pm
trd4life wrote:Well as most of you know i have pounded on my car for years now using nitrous and then a TRD supercharger at 7psi on stock internals. At 111,000 she finally let go. I went to check my oil this morning and it was creamy foamy looking. I assume its a head gasket. Time for a rebuild. Can you guys point me in the right direction on where to order pistons, rods, and head studs. thanks
Well it would be kind of far but I would strongly recommend Arrieta Motor Sports as Greg mentioned. Even if they are too far away and you want a local place to do the work, I would at least give them a call and see if they can help you out with the parts needed. Everyone knows ARP is the KING for head studs. You probably also know from previous posts that ARP does not make a set for our engine. I think Arrieta Motor Sports can help you out there too. -JoeB
JoeB
Postby Alex(AUS) » Sun Jan 23, 2005 2:14 am
13.5 @ 107 is VERY quick and the dyno numbers arent too shabby either :lol: . Top effort considering the 111k miles. Many would have risked it to get those times/numbers (particularly the 107mph).
I guess with a rebuild it can only go better :o
Alex
Alex(AUS)
Postby TRD_solaRa » Sun Jan 23, 2005 10:18 am
Alex(AUS) wrote:13.5 @ 107 is VERY quick and the dyno numbers arent too shabby either :lol: . Top effort considering the 111k miles. Many would have risked it to get those times/numbers (particularly the 107mph).
Alex
I agree. I would risk it to get :o 13.5s anyday! Especially in Hawaii. Knowing this . . . hmmmmmm I jus might skip the show part and go right on ahead to the charger. :drinking: Good luck on the rebuild buddy! Shootz den.
TRD_solaRa
Postby shidosha01 » Sun Jan 23, 2005 6:22 pm
Arrieta Motorsport. 301-856-2886 Ask for Carlos Jr. Sorry to hear about you blowing motor.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Return to Forced Induction
