SolaraGuy.com • View topic - cleaning the ik22?
cleaning the ik22?
cleaning the ik22?
Postby jerold » Sun Feb 13, 2005 7:27 pm
if you're not supposed to regap the iridium plugs, since it might damage the plating, how do you clean all the gunk off of a used one?
if it's already used, is it ok to regap? and scrape off the gunk with a wire brush? or is there a solvent or something?
thanks,
jerold
2000 camry
jerold
Postby Parke10 » Tue Feb 15, 2005 12:15 am
why not just buy new ones?
Parke10
Postby Turbosolara » Tue Feb 15, 2005 6:25 pm
denso iridium has very short life span. mine usually last less then 20000 miles. just buy a new one, or you can buy Denso one for cheaper price
EDIT: I mean NGK one is cheaper!!!
Postby jerold » Wed Feb 16, 2005 6:11 pm
do you know where to get some? i tried some of the pepboys, autozone, kragens around the LAX area. somebody had IK20s. nobody had IK22.
thanks,
jerold
2000 camry
jerold
Postby Turbosolara » Wed Feb 16, 2005 9:57 pm
call this shop (714) 890-1247, they have really good price for about 10 dollars each. they locate at garden grove.
but are you running supercharger?
Postby jerold » Thu Feb 17, 2005 1:30 am
urd 7 psi, fuel upgrade, jim's heads, etc. but i rarely run with boost. (if you think about all of the hours spent driving, really, only a couple of seconds are spent with boost.) i just like that it's available, if i need it. i'm thinking of switching back to the IK20. any thoughts?
2000 camry
jerold
Postby Turbosolara » Thu Feb 17, 2005 11:04 am
sounds like a good set up but have you tuned your car with any air fuel ratio control advice? a untuned motor would kill the spark plug fast due to extreme lean and rich condition.
Postby jerold » Thu Feb 17, 2005 4:02 pm
nope. i was trying to avoid spending the extra $300+. boy does this all get expensive. gotta remind myself not to mod the next car. thanks.
2000 camry
jerold
Return to Forced Induction
