SolaraGuy.com • View topic - s/c auto transmission
Postby Hsakuragi » Wed Feb 23, 2005 10:45 pm
for y'all s/ced people with automatic, how does it feel when you shift the gear from P to R? Did it give u a "shake" when u do that? my does and hope i'm not the only one....
Hsakuragi
Postby happy_aggies » Thu Feb 24, 2005 8:21 am
It's probably the brass for the boost gauge hitting the strut bar.
happy_aggies
Postby shidosha01 » Thu Feb 24, 2005 9:22 am
happy_aggies wrote:It's probably the brass for the boost gauge hitting the strut bar.
I second that. Good to see you around again happy aggies. :)
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby Hsakuragi » Thu Feb 24, 2005 9:36 am
i already has 3 washers on each screw to make the sturt bar higher, it seems pretty clear around the area or is there any other way?
Hsakuragi
Postby Paladin06Greg » Thu Feb 24, 2005 9:59 am
I marked the area where my 90 degree elbow was going to be installed. I removed my strut brace and took it to a machine shop. They removed a half circle shape piece of metal in the area I had marked. They buffed the area smooth, repainted the area and applied a small rubber strip. Looks like it came from TRD that way. This did not have any negative impact on the bar as I asked that question of TRD and Toyota before modding my bar.
Good Luck. 8)
Cost
hsakuragi wrote:i already has 3 washers on each screw to make the sturt bar higher, it seems pretty clear around the area or is there any other way?
Paladin06Greg
Torqued Solara
Torqued Solara
Postby JoeB » Thu Feb 24, 2005 10:50 am
I couldn't raise mine high enough to get it off the fitting. I ended up tapping a hole in the side of the sc housing for the boost fitting. To see if tthat is definitely the problem, try putting something on top of the fitting that will transfer if it touches. I don't have a good idea off hand, maybe a dab of grease or something. -JoeB
JoeB
Postby 209solara » Thu Feb 24, 2005 12:32 pm
this is a common problem, i went the way of the dremmel.
209solara
fitting
Postby trd4life » Fri Feb 25, 2005 7:05 am
I just looked around until i found a fitting that sat low enough without hitting the strut bar, no washers needed.
Re: fitting
Postby Paladin06Greg » Fri Feb 25, 2005 7:10 am
Congrats. Make sure it clears when you hit the throttle in reverse as well as in drive.
trd4life wrote:I just looked around until i found a fitting that sat low enough without hitting the strut bar, no washers needed.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby JoeB » Fri Feb 25, 2005 8:07 am
Maybe there is a difference between the auto and the manual as far as clearance goes? I took a fitting that someone else used that didn't hit for him and it still hit on mine. Then I sheved it down even lower and still hit. I took it out and had my wife sit in the car and put in in reverse while holding the brake (reverse is the worst). With no fitting at all, the bar just barely clears the sc. -JoeB
By the way, I know the automatic has a different front motor mount than the manual.
JoeB
Postby Paladin06Greg » Fri Feb 25, 2005 8:15 am
JoeB,
What you say is exactly right. That's why I had my bar modded.
JoeB wrote:Maybe there is a difference between the auto and the manual as far as clearance goes? I took a fitting that someone else used that didn't hit for him and it still hit on mine. Then I sheved it down even lower and still hit. I took it out and had my wife sit in the car and put in in reverse while holding the brake (reverse is the worst). With no fitting at all, the bar just barely clears the sc. -JoeB
Paladin06Greg
Torqued Solara
Torqued Solara
Postby ChargedSolara » Wed Mar 09, 2005 2:19 pm
i never was able to get my boost fitting to clear my strut bar..but my auto s/c'ed solara doesnt make that sound..probably cuz i dont have the strut bar, it does make a dull thud when shifting from P to R but i'm assuming thats just the tranny/engine getting older..
2008 C6 LS3
ChargedSolara
Return to Forced Induction
