SolaraGuy.com • View topic - Question for 1mz-Fe guys using the MSD DIS-4 ignition
Postby trd4life » Fri Feb 25, 2005 4:48 pm
Do you guys like the DIS-4? What additional adapters are neccesary for it to work on the 1mz-fe? Can the stock rev limiter be removed? Whats the cost?
Thinking about ditching the Ignition Solutions Plasma Booster and geting the DIS-4.
Postby supamouse09 » Sat Feb 26, 2005 12:25 am
i dont have a msd 4 but i removed the rev limiter and speed limiter
01 Toyota Solara SLE V6 Manual Swap
supamouse09
Postby Alex(AUS) » Sat Feb 26, 2005 7:00 am
I remember Greg saying something about removing the rev limiter with the MSD-4. Just make sure it is of benefit and you arent just killing the engine.
Also, why not replace the ignition units with some high performance ones. Turbo magazine used some variation of these in the MR6 buildup.
Alex
Alex(AUS)
Postby JoeB » Sat Feb 26, 2005 12:06 pm
supamouse09 wrote:i dont have a msd 4 but i removed the rev limiter and speed limiter
How did you do that? Also, did you remove the rev limiter or change it? Do you have an auto or manual? If auto, what happens to the shift points when you remove the rev limiter? Very interested. -JoeB
JoeB
rev limiter
Postby trd4life » Sat Feb 26, 2005 12:29 pm
The motor i am having build has a built valvetrain so i figured it could rev the motor a little higher as long as its benficial on the dyno.
Postby Turbosolara » Sat Feb 26, 2005 4:50 pm
why dont you just use ignitionsolution unit? there were few people in teamsc3 froums used and they felt great about it
Postby JoeB » Sun Feb 27, 2005 8:37 am
UltraslowSolara wrote:why dont you just use ignitionsolution unit? there were few people in teamsc3 froums used and they felt great about it
Joseph, the only thing I remember from Ignition Solutions is the Plasma Booster. Are you talking about that or something else? If it's the Plasma Booster, is there a way to change rev limit and speed limiter with that? -JoeB
JoeB
Postby DatSRBoi » Sun Feb 27, 2005 10:55 am
Ive never heard of this Plasma Booster before. What is it and what does it do? Mo Power?
Re: Question for 1mz-Fe guys using the MSD DIS-4 ignition
Postby Paladin06Greg » Sun Feb 27, 2005 11:17 am
I must say that I'm pleased with mine. You will need two 8910 Tach Adapters. The DIS-4 will run you between $350.00 and $400.00 and the adapters run from $25.00 to 30.00.
The DIS-4 Part number is 6215.
The Rev limiter can not be removed but it can be slightly raised.
Try here for pricing and info.
http://www.enrracing.com/category.cfm?C ... C=standard
http://www.enrracing.com/moreinfo.cfm?Product_ID=62
trd4life wrote:Do you guys like the DIS-4? What additional adapters are neccesary for it to work on the 1mz-fe? Can the stock rev limiter be removed? Whats the cost?
Paladin06Greg
Torqued Solara
Torqued Solara
Postby supamouse09 » Sun Feb 27, 2005 10:48 pm
i did the auto to manual tranny swap and i can rev it so it slappes the 8k rpm mark and there is no bog can any one tell me why??
supamouse09
Postby Turbosolara » Mon Feb 28, 2005 12:57 am
yes i am talking about plasma booster but i dont think it can change the rev limit and speed limt.
Postby Alex(AUS) » Mon Feb 28, 2005 3:14 am
Hey guys what about the ignition units they used in the turbo mag MR6 buildup? They were from ignition solutions ....
Alex
Alex(AUS)
Postby JoeB » Mon Feb 28, 2005 8:36 am
^^^ Alex, I don't remember what they used. Can you shed some light here? Did they say anything about them? -JoeB
JoeB
Postby Alex(AUS) » Tue Mar 01, 2005 5:39 am
The mag states "ignition solutions plasma-booster direct-fire coils solved all sparking problems at a .029 spark plug gap". They even have a photo of them ... they look high tech :lol:
How do you attach an image here?
Alex
Alex(AUS)
Postby Paladin06Greg » Tue Mar 01, 2005 5:43 am
[img]you%20pic%20url[/img] Enter it into the signature block of your profile.
Enjoy.
Alex(AUS) wrote:The mag states "ignition solutions plasma-booster direct-fire coils solved all sparking problems at a .029 spark plug gap". They even have a photo of them ... they look high tech :lol:
Alex
Paladin06Greg
Torqued Solara
Torqued Solara
Return to Forced Induction
Users browsing this forum: No registered users and 278 guests
