SolaraGuy.com • View topic - idle question
idle question
idle question
Postby goldentoy » Mon Mar 28, 2005 8:59 pm
i started my car after installing the sc and it idles at 200 rpm and my injen intake is really sucking in air. you can hear a slight beep in the car too. the car stays at that range but no check engine light. just when i thought i was in the clear. also i was wondering if it is a knock sensor problem. can you actually have a blown sensor without a check engine light on your car? thanks in advance for any help
goldentoy
Postby SC V6 » Mon Mar 28, 2005 9:12 pm
the car is going to take a bit to get used to the S\c... its just adjusting to the new addition.. in good time it will run like it used 2 (idle normal)
SC V6
Postby goldentoy » Mon Mar 28, 2005 9:45 pm
thanks man for info. s/c equal big time stress hahah :P
goldentoy
Postby SC V6 » Tue Mar 29, 2005 6:28 am
I know exactly that you mean... you just want to make sure everything runs perfect... it worried me a lot when I did mine also
SC V6
Postby Paladin06Greg » Tue Mar 29, 2005 6:34 am
It can take as much as ten days for the computer to reset itself to the SC. Just go easy on it for a little bit.
goldentoy wrote:thanks man for info. s/c equal big time stress hahah :P
Last edited by Paladin06Greg on Tue Mar 29, 2005 10:11 am, edited 1 time in total.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Hsakuragi » Tue Mar 29, 2005 10:08 am
200 rpm??
Hsakuragi
Postby SC V6 » Tue Mar 29, 2005 11:36 am
could be a vacuum leak 2.. by the way
SC V6
Postby goldentoy » Tue Mar 29, 2005 9:32 pm
yep it was a vacum leak. on the install when you cut the iac hose i didnt reconnect with the one way valve. i just left it hanging with the plastic tip. also the hose going to the egr pipe and the one on the s/c i switched. dam im a noob. i was trippin this whole morning now im all g. i give u guys props for helping me out.
goldentoy
Return to Forced Induction
