Good news for the 2azfe from scionspeed
They just pulled 426 whp and 374 wtq on stock internals at 18 psi....STOCK INTERNALS!
xavier - SolaraGuy Street Racer
attaboy 2azfe! Kudos to TC owners....
yeah... but for HOW LONG can it go on stock internals on 18lbs?
Mole wrote:yeah... but for HOW LONG can it go on stock internals on 18lbs?
the question is.. was it blown at the time of the dyno w\ 18psi.. and also, what octane fuel, and how rich was it running?
Now, that's just SICK!!!!
2AZ Solaras and 2AZ tCs are tuned slightly differently (weight of car) and the parts are not as interchangable as you'd like...
but w/ minor changes to JP Performance's header... you can make a turbo manifold =D
SC V6 wrote:what im sayin about it being blown is.. it could have had problems prior to the dyno... i.e. broken piston lands and not knowing it
Jackass-Jeff wrote:SC V6 wrote:what im sayin about it being blown is.. it could have had problems prior to the dyno... i.e. broken piston lands and not knowing it
The 2AZ was designed to be the ultimate beater engine. I'm sure Toyota will see the potential of the 2AZ and release a RWD car using the 2AZ... 300 WHP 2.4L single Turbo... that's awesome.
You can't really call the 2AZ a "platform". It's an engine. A platform would be a car/body style. So you would like to see the ANT10 platform mods being applied to ACV20 and ACV30 platforms, but it may never happen.
400 WHP may seem cool now... but when you're at the track... you realize you can only go straight =P
Moderation is always the key... it's the golden rule. You can't spend your entire paycheck on a 400 WHP turbo kit... you also need to get the proper suspension (including Rims and Tires) to make sure your car can turn/reduce wheel hop/etc... you also need upgraded brakes to make sure you can stop after going so fast...
Honestly, I hope they do not apply it to the Solara platform. We're just gonna see a bunch of wrecked Solaras and people being pulled over all the time because they aren't responsible enough to handle 400 HP yet.
The Veterans remember Ryan (Flipside909)... now I know where he was coming from... it's funny hahaha
