SolaraGuy.com • View topic - Where to go for Supercharger rebuilds?
Postby SpeedSTARs » Sun May 01, 2005 9:30 pm
Hello everyone,
I was wondering if you guys knew if there was a good place to send your TRD supercharger in for a rebuild. Do you guys have any suggestions???
Thanks in advance,
-G
SpeedSTARs
Postby StockSolara » Sun May 01, 2005 9:32 pm
http://www.gadgetonline.com/Supernose.htm this site should beable to help you out on maintence.
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby SpeedSTARs » Sun May 01, 2005 9:47 pm
Many thanks StockSolara...
Is Magnuson the company that did the R&D (research and development) on the TRD Charger? Anyway, thanks again.
Best regards,
-G
SpeedSTARs
Postby cdssolara » Sun May 01, 2005 11:56 pm
Best regards,
-G
Yes, I believe they did. You should be able to go to them about servicing.
cdssolara
Postby SpeedSTARs » Mon May 02, 2005 10:22 pm
Many thanks guys,
You've been very helpfull... May the boost be with you!
LOL,
-G :P :D
SpeedSTARs
Postby JoeB » Tue May 03, 2005 5:49 am
There is another place other than Magnusen to rebuild the sc. I believe it's in CA, some of the guys used this place a while ago but I can't remember the name. Supposedly they use even better parts in the rebuild than Magnusen does. I'll try to see if I can find a name. -JoeB
JoeB
Postby gLok » Thu May 05, 2005 2:30 pm
Before i got the turbo bug i was going to send my supercharger back to Magnuson to get rebuilt. I got all of their information here to help anyone who might need to contact them.
Magnuson Products, Inc.
3172 Bunsen Ave. Unit D
Ventura, CA 93003
(805) 289-0044 - Phone
(805) 642-1936 - Fax
Hours: M-F 8:30AM-5:00PM (PST)
www.MagnusonProducts.com - Web Site
99 Camry V6 5 speed - built 1mz +++
90 Integra LS 5 speed - daily beater
http://www.legacytuning.com
http://www.grantscustomrigging.com
gLok
Postby SpeedSTARs » Fri May 06, 2005 12:52 am
gLok wrote:Before i got the turbo bug i was going to send my supercharger back to Magnuson to get rebuilt. I got all of their information here to help anyone who might need to contact them.
Ventura, CA 93003
Thank you very much for the info. You rock. :wink:
-G :) :) :)
SpeedSTARs
Postby SBCelicaGT » Fri May 06, 2005 10:21 am
Best regards,
-G
Other way around. As with Jackson Racing blower kits, TRD designs the kits and has Magnuson make them by taking the TRD design that utilizes the Eaton blower.
1990 Toyota Celica 1MZ V6
14.7@95mph @ Famoso
All motor. hehehehehe.
SBCelicaGT
Postby SpeedSTARs » Fri May 06, 2005 9:57 pm
Best regards,
-G
Thanks for the info. I take it that Magnuson is like a Tier 1 supplier for the OEM. Sweet. :D
-G :P :P :P
SpeedSTARs
Postby that1mexguy » Sat May 07, 2005 9:01 am
Not sure if I'm going off topic here but ... is there a reason to rebuild a supercharger, other than damage?? i guess what i'm asking is, could a supercharger be rebuilt to get even more boost? and would it be even worth it? just curious ... thanks
that1mexguy
Postby SpeedSTARs » Sat May 07, 2005 9:54 pm
that1mexguy wrote:Not sure if I'm going off topic here but ... is there a reason to rebuild a supercharger, other than damage?? i guess what i'm asking is, could a supercharger be rebuilt to get even more boost? and would it be even worth it? just curious ... thanks
SUP Bro,
The answer is "yes" it could be design to increase more boost. It would be done by changing the gear ratios in the charger fo the scrolls to spin faster.
What our Solara's need is an intercooler with that extra boost. The point being is that the faster the scrolls spin, the most heat is present in the chamber of the blower. The intercooler would solve this problem to produce a higher density of air verse the heat build up in the chamber that reduces the efficiency of the charge.
What really sucks, is that,in order to package the intercooler on the GEN1-1.5 Solaras, the hood and strut tower brace would have to be changed to accomadate the cooler to fit under the hood. The cooler fits in between the TRD blower and the cylinder head.
Plan B- Would be to have the air intake manifold ports (air plenum) of the Eaton style TRD blower bored, homed and tapered/ chamfered to increase airflow to the cylinder heads. You can expect 8-20HP @ the wheels by doing this project. However, with all these special projects, money and time is always an issue... In fact you can find more info on this stuff in the newstands under the magazine MODIFIED MAG's June 2005 issue. The article is titled, "Intake Manifold Design & Testing" page 117-122. Hope you enjoy the article as much as I did.
-G :turn-l: :turn-l: D guys
SpeedSTARs
Postby SpeedSTARs » Wed May 25, 2005 8:02 pm
Ok Guys,
I ended up sending the charger to Magnuson. They ended up replacing the rotor, the Bearings, nose cone assembly and silenoid. I must say, they did a fantastic job in rebuilding the blower. The contact person I went through was a gentlemen named David Gonzalez of Magnuson Products.
The place to send your superchargers is listed on the address below along with the contact information:
CONTACT US
1990 Knoll Drive
Ventura, CA 93003
(805) 642-8833- Phone
(805) 677-4897 - Fax
Also if you want to go directly to Dave for the RGA# issuing, his extention is listed under #261
Many thanks to all my Solara brothers. :P
-G
SpeedSTARs
charger
Postby hskrsolara » Mon Jun 27, 2005 7:06 pm
How much did it cost for the rebuild?
hskrsolara
Re: charger
Postby SpeedSTARs » Mon Jun 27, 2005 8:43 pm
hskrsolara wrote:How much did it cost for the rebuild?
SUP Bro,
They basiclly replaced every component of the charger. It totaled to be around $650 plus shipping... :-?
Anyway... How is yours (SC) holding up? The staff at Magnuson are pretty cool. :wink: 8)
Peace,
-G
SpeedSTARs
Return to Forced Induction
