SolaraGuy.com • View topic - my car is due for major service
Postby Hsakuragi » Tue Jun 28, 2005 8:39 am
ok..going to hit 60k in next 400 miles....i'll bring the car back to the dealer for the major service. Should I change the timing belt and the water pumps since they have to take off the charger to install the spark plugs or should I wait until 90k? I do step on the car pretty hard....
I rememeber a LONG time ago someone posted of what the dealer will do for major, anyone still have that?
Hsakuragi
Postby Astro » Tue Jun 28, 2005 3:57 pm
This is from North Hollywood Toyota:
[url=http://www.northhollywoodtoyota.com]Image
[/url]
Postby aforz2breckonedwith » Mon Jul 04, 2005 7:42 pm
i got my major sched maint. done not to long ago and i cost me a hefty penny. around $700, and thats with ngk spark plugs witch was about $11 a peice, spark plug cables, timing belt and, coolant and tranny flush.
aforz2breckonedwith
Postby Hsakuragi » Sat Jul 09, 2005 4:20 pm
1400...
Here the list of what they gonna do...
Major Service (no oil changeair filter/tire rotation need)
spark plug cable
timing belt
drive belt + cam seals + water pump +gasket....
Hsakuragi
Postby SPF 0 » Sat Jul 09, 2005 5:42 pm
I'd check straight away as to what the owner's manual calls for. Seemingly every dealer has their own idea of what maintenance is called for at given time/mileage point.
FWIW, I've always changed timing belts at 60,000; I have no idea what "cam seals" are. If it's going to save you a bunch of money to do that water pump now, I might go ahead as the part itself is generally fairly inexpensive on the vehicles I'm familiar with (READ: Not Solaras).
SPF 0
Postby TRD MCV20L » Sat Jul 09, 2005 8:57 pm
Astro wrote:This is from North Hollywood Toyota:
[/url]
Thats a really good price. You might want to add a brake fluid flush (bleed the brakes) to that list.
TRD MCV20L
Postby SPF 0 » Mon Jul 11, 2005 4:15 pm
I'm not sure I can agree with you 100%. I looks to me like they're basically changing the oil, air filter, draining (not flushing) the trans fluid, changing the plugs (V6s are extra), and possibly rotating the tires for $259. Of course, who knows how much the "hazardous waste removal fee" would be.
As far as the inspections go, I would imagine a dealership's service department would be fairly agreeable to inspect those items for free; this would give them a chance to find more service work that you need.
As far as the rental car. . .most dealerships I've gone have service loaners available gratis.
Howard's 2¢ Worth
SPF 0
Postby SPF 0 » Mon Jul 11, 2005 4:41 pm
BTW, I live in the Chicago area. This could be a screaming bargain in Kal-e-Fron-A.
SPF 0
Return to Forced Induction
