SolaraGuy.com • View topic - nitrous oxide installation
Postby gsolara » Tue Jul 26, 2005 5:12 pm
i just got a wet nitrous kit, and i am wanting to install it myself. The only problem i am worried about is tapping into my fuel line. Has anyone installed nitrous on their solara? or can any one give me some help or hints? 2001 SLE V6
gsolara
Postby StockSolara » Wed Jul 27, 2005 12:33 pm
Just cut the line. . . You can always reconnect it with a tube. . . Have fun you will love it :D
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby WTF?? » Wed Jul 27, 2005 4:34 pm
^LOL.. what a great influence! :D
Retired... its been fun Image
WTF??
Postby dominoSLEV6 » Wed Jul 27, 2005 11:20 pm
WTF?? wrote:^LOL.. what a great influence! :D
I was gonna say this too. I think if I had a friend liek that I'd proably be dead.
-chris
dominoSLEV6
Postby StockSolara » Thu Jul 28, 2005 12:15 am
-chris
haha. . . someone has got to be a motivator sometimes
2000 Lexus GS400
StockSolara
Postby SeanJohn0716 » Wed Mar 22, 2006 9:58 am
StockSolara wrote:Just cut the line. . . You can always reconnect it with a tube. . . Have fun you will love it :D
I've got a 5S-FE, where sould I cut the fuel line? I have a dry setup and I'm trying to turn it into a wet one. Any help on cutting the fuel line will be appreciated
BTW, sorry for reviving a dead thread
SeanJohn0716
Postby StockSolara » Wed Mar 22, 2006 1:17 pm
On the fuel line between the fuel rail and fuel filter
2000 Lexus GS400
StockSolara
Postby SeanJohn0716 » Wed Mar 22, 2006 4:09 pm
Hmm... I'm just shaky about cutting the line and making sure its secure when I add the T fitting. What should I use to tap it with a T?
SeanJohn0716
Postby dominoSLEV6 » Wed Mar 22, 2006 4:53 pm
SeanJohn0716 wrote:Hmm... I'm just shaky about cutting the line and making sure its secure when I add the T fitting. What should I use to tap it with a T?
Just cut the line and put the T in with the orginial line being connected by the parallel ends, and the hose going to the solonoid connects to the other. Make sure you have the proper size hose to runt he fuel to the solenoid and I would also strongly recommend using clamps on the hoses at the t connections. I havebn't installed nitrous on a Solara before, but I have a kit ready to go, bottle fille din my garage, I just changed my spark plugs to iridiums so now I'm finally good to go. I've scoped out the situation plenty so it should all go smoothly, but in either case, that's the way to tap the fuel line.
Good luck.
-chris
dominoSLEV6
Postby SeanJohn0716 » Wed Mar 22, 2006 6:01 pm
Good luck.
-chris
I guess thats PART of what i am asking. My real concern is WHAT to use for the t fitting. One of those little plastic ones from the local auto shop? Or should I use 1/4" pressure fittings like I did for all the other parts of the system? Again, I've had the dry setup in my car for about a year, and it is all good, I just need to add in the fuel solenoid and new jets
SeanJohn0716
Postby StockSolara » Wed Mar 22, 2006 6:17 pm
Good luck.
-chris
It should come with the kit
2000 Lexus GS400
StockSolara
Postby SeanJohn0716 » Wed Mar 22, 2006 6:27 pm
I peiced my kit together over about a month. Again, it was originally a dry kit
SeanJohn0716
Return to Forced Induction
