SolaraGuy.com • View topic - supercharger for Avalon 3.0 VVT-i?
Postby avalon01 » Fri Aug 19, 2005 3:25 pm
i've heard conflicting reports about the TRD supercharger working or not working on the Avalon's 3.0 with VVT-i on the toyotanation forums. U solara guys seem pretty smart, do you know if it'll work?
also is the supercharger the best way to go with toyota v6's? I keep reading about busted piston threads on here. :-?
avalon01
Postby SC V6 » Fri Aug 19, 2005 3:46 pm
VVti is similar to Vtec, and the problem with that is that at higher RPM's the camshafts slide over and make the duration for exhaust and intake greater... they overlap a bit which is what causes the delima for boosting a Vtec or VVTi... the overlaping of the intake and exhaust duration makes it damn near impossible to hold any boost in the cylinder
SC V6
Postby krawzyazn » Fri Aug 19, 2005 3:52 pm
thats why they have V-tec controllers but I dunno if they made one for VVT-i
Postby Somedude » Fri Aug 19, 2005 3:54 pm
you could always use nitrous, that will save you some money.
Somedude
Postby SC V6 » Fri Aug 19, 2005 4:02 pm
V-tec controllers just make it so you can adjust when the vtec kicks in right? RPM wise that is
SC V6
Postby avalon01 » Fri Aug 19, 2005 4:12 pm
[url=http://64.233.167.104/search?q=cache:NoOFQjnrppMJ:www.autoweb.com.au/cms/A_55446/newsarticle.html+vvt-i+supercharger&hl=en&start=3&client=firefox-a]
"uses the proven Toyota 3.0 litre all-alloy VVT-i engine equipped
with Toyota's own supercharger which is coupled to an
existing 4x4 drivetrain...A supercharged three-litre VVT-i
equipped all-alloy Quad Cam V6 engine powers Toyota
Australia's first in-house concept vehicle - the most powerful
engine ever fitted to an Australian built Toyota. Its
supercharger, sourced from Toyota performance equipment
specialist TRD USA, is belt driven by the V6 engine's crankshaft."[/url]
so you can get a TRD supercharger to work just fine with VVT-i, but how?
avalon01
Postby DatSRBoi » Fri Aug 19, 2005 4:57 pm
Postby Turbosolara » Fri Aug 19, 2005 11:53 pm
DatSRBoi wrote:http://solaraguy.org/viewtopic.php?t=19461
it still doesnt help him because the issue is the high compression in the vvti motor.
power enterprise just released a vvti/vtec controller, maybe you can take advantage of that.
http://www.power-enterprise.co.jp/
Postby avalon01 » Sun Aug 21, 2005 6:46 pm
um, well i dont read japanese so i dont know what it says but that's interesting. Google says 39,900 yen is ~$361 USD
avalon01
Postby Turbosolara » Sun Aug 21, 2005 8:56 pm
i first saw this at a import car magazine back in june. they had a article explain how that thing works, but i forgot which magazine. my guess is superstreet. search around, you might find some distributor of power enterprise.
Postby avalon01 » Mon Aug 22, 2005 9:31 am
Turbosolara wrote:i first saw this at a import car magazine back in june. they had a article explain how that thing works, but i forgot which magazine. my guess is superstreet. search around, you might find some distributor of power enterprise.
i searched google and froogle, no one distributes the power enterprise vvti controller
avalon01
Postby avalon01 » Mon Aug 22, 2005 9:35 am
nevermind, i called these guys: subarustore
and they carry it, said it's $475, but they dont know anything about it since it's new.
ok... so i get the boost controller, then what? TRD supercharger? What about all these horror stories of busting pistions? Anyone sell forged pistions? I mean if i'm gonna do this i might as well spend a little extra $$$ and get it done right the first time, nothing worst than a money pit car.
avalon01
Postby Ford_Fixorrepairdaily » Mon Aug 22, 2005 10:11 am
Its not necessary to upgrade your pistons and internals unless you want to run more then 6psi. 5.5 is the limit for stock internels. Even at that you would need some other upgrades to boost safetly. THere are lots of informative people on this board. Pretty sure youll find what you need.
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby Turbosolara » Mon Aug 22, 2005 7:38 pm
that is not a boost controller, it is a vvti controller. if you gonna supercharge yoru car, the pulley and belt is your boost controller.
Return to Forced Induction
Users browsing this forum: No registered users and 80 guests
