SolaraGuy.com • View topic - Superchargers???
Superchargers???
Superchargers???
Postby M_ABILLONES » Fri Sep 23, 2005 10:00 pm
I'm new to tuning Solaras so here goes: I'm planning on adding a TRD Supercharger in my Solara & I was wondering which aftermarket companies make:
a. High Flow Fuel Pump(Walbro I'm pretty sure right?)
b. High Flow Fuel Rails
c. High Flow Fuel Injectors
d. Adjustable Fuel Pressure Regulator
Also, when doing a Supercharger install, what else should I do to extract every bit of horsepower from the engine (I'm thinking of getting a minor porting and polishing from the intake and exhaust side)...
Thanks,
Mark
M_ABILLONES
Postby ~Spadwaller~ » Fri Sep 23, 2005 10:04 pm
If you've got money
http://www.urdusa.com/product_info.php?products_id=110000017
and don't forget
Jim's fuel upgrade
~Spadwaller~
Postby M_ABILLONES » Fri Sep 23, 2005 10:07 pm
Dude thanks for posting that up. That's exactly what I'm looking for...a complete fuel kit for a "boost" install...actually $899 is pretty cheap for this kinda set up...i had a wrx before and the whole fuel system costed me close to $2000...perrin, aps, all that jdm expensive stuff
M_ABILLONES
Postby ~Spadwaller~ » Fri Sep 23, 2005 10:09 pm
My paypal is addy is spadwaller@hotmail.com if you wanna put alittle rattle in my cup. :lol:
~Spadwaller~
Postby arch.HI » Sat Sep 24, 2005 12:05 am
M_ABILLONES wrote:How about some High Flow Fuel Rails? Any companies out there make them for Solaras?
Nope
2000 Camry LE V6
TRD Supercharged
arch.HI
Postby Astro » Sat Sep 24, 2005 12:08 am
-sorry I accidentally erased your post.
No fuel rails, unfortunately. Also, we can't use the adjustable fuel regulator. Our stock ones flow good enough. I just had all those installed, I just need to upgrade my clutch, tune the S-AFCII on the lo throttle with the ODBII scanner, then I can hit the dyno for the hi throttle. Don't forget to look at getting a Supra TT MAF kit sold here by trd4life (Gabe). Good luck!!
Postby arch.HI » Sat Sep 24, 2005 12:12 am
You'll also want to get Jim @ Foreign Affairs fuel line upgrade kit. It comes with higher flowing fuel filter and lines from the filter to the fuel rails. Give him a call at 503-236-2871
2000 Camry LE V6
TRD Supercharged
arch.HI
Postby Astro » Sat Sep 24, 2005 12:25 am
arch.HI wrote:You'll also want to get Jim @ Foreign Affairs fuel line upgrade kit. It comes with higher flowing fuel filter and lines from the filter to the fuel rails. Give him a call at 503-236-2871
Man, I forgot the most important mod!! :drinking:
Postby Fletch » Mon Sep 26, 2005 3:43 am
As I'm sure you have surmised, the fuel upgrades, especially with a A/F piggyback will allow you to safely push some more air than stock 4psi. The general consensus is that 6psi is the absolute limit with stock internals, several have chosen to stick with a safer 5.5psi (2.9" I think).
Pulleys are available at pulleyboys.com and a few other places.
2006 Legacy GT spec.B
Fletch
Postby M_ABILLONES » Mon Sep 26, 2005 7:08 am
Someone should make a set of upgraded fuel lines for the solara. I mean an increase of 50+ horsepower is enough to deprive the engine from a restrictive stock fuel line...just from my experience with tuning a wrx it's a must that i replace all the stock fuel components in favor for a more flowing aftermarket ones...i just hope that the solara's stock fuel lines flows evenly to all the cylinder under idle and full load...hate to see a cooked piston....
M_ABILLONES
Postby Dimik » Tue Oct 04, 2005 9:28 pm
finally some one answered where to get jim's fuel kit, how much is it??
Dimik
Postby DatSRBoi » Tue Oct 04, 2005 9:47 pm
M_ABILLONES wrote:Someone should make a set of upgraded fuel lines for the solara. I mean an increase of 50+ horsepower is enough to deprive the engine from a restrictive stock fuel line...just from my experience with tuning a wrx it's a must that i replace all the stock fuel components in favor for a more flowing aftermarket ones...i just hope that the solara's stock fuel lines flows evenly to all the cylinder under idle and full load...hate to see a cooked piston....
Didnt you see.
Postby Dimik » Thu Oct 06, 2005 2:18 pm
how much!! how much!!?!? :o
Dimik
Postby Fletch » Fri Oct 07, 2005 3:28 am
FA fuel kit is $200.
Fletch
Postby Dimik » Sat Oct 08, 2005 8:46 pm
200, cool, now.. is it pointless to get it without a supercharger?
Dimik
Return to Forced Induction
Users browsing this forum: No registered users and 64 guests
