SolaraGuy.com • View topic - Rewiring the ECU (How?)
Postby bunthy » Mon Sep 26, 2005 6:04 am
Hey guys,
Well i think I blew my knock sensor. I didn't get it check yet but from reading some of the threads, I think I did. The car still runs fine, not sluggish, but I'm not flooring it since the CEL came on.
I read that Jim's Fuel upgrade will help or rewiring the ECU. The JFU is pretty expensive, at least from my POV, so I wanna go the rewiring route. Do you guys have a DIY tutorial for it? Or a weblink to get to? Also would it be something that I would be able to do? I'm handy here and there but not hardcore stuff.
Thanks!
p.s. My car is a 96 avalon running @ 4psi and IK22 plugs.
bunthy
Postby Fletch » Mon Sep 26, 2005 6:56 am
This thread is full of information, I remember pictures of the ECU behind the glove box, but don't know if it's in here.
http://www.solaraguy.org/viewtopic.php? ... ecu+rewire
Take the glove box out and look for (2) clear shielded wires.
If I would have known, I would have gladly spent $200 on the FA Fuel Kit to prevent blowing a knock sensor.
2006 Legacy GT spec.B
Fletch
Postby bunthy » Mon Sep 26, 2005 7:40 am
Thanks Fletch. I was reading through the thread and saw the diagram (E11, E10, E9, E8, E7). On my Avalon, when I wired teh EBC, I only had E10, E9, E8, E7. But E10 was the biggest one, I believe as big as E11.
These wires should be here right? Once I do that, and if it works, do I need to replace my knock sensors? The engine doesn't knock....at least I don't hear it....
bunthy
Postby bunthy » Mon Sep 26, 2005 6:02 pm
wekk I tried it out. the wiring is a little bit different but in any case it worked. the CEL is off now and everyth8ing feels good so far.
On the 96 avalon, the wires is located on E8 # 14 and 15, with 15 being the rear #1 knock sensor. Their both clear wires. Thanks alto for your help.
bunthy
Return to Forced Induction
