SolaraGuy.com • View topic - Who use their SC Solara as daily and travel?
Postby DatSRBoi » Mon Nov 21, 2005 9:36 am
I know boosting too much is bad. I know boosting too long can cause heat issues. But who uses their SC solara as daily driving and or traveling out of state or cities? Do you let you car rest every hour or so? How many miles do you go at it? Im about to travel out of town and was just wondering. Ill only be at 4 psi.
Postby wiz2 » Mon Nov 21, 2005 10:24 am
Ive been boosted since 12/20/03 and have a little over 51,000 boosted miles,91k total. Most mileage was with a 5.5 pulley. It's my daily driver rain sleet or snow. I've never rested for anyhing when traveling except to pee or change a diaper. No, not my own. hahahah.
My longest trips have been up to Deals Gap to run the Dragon. After that I turned around and drove home, about 4 hrs each way. I've also driven to Atlanta and back in the same day about 4 hrs each way. I'm actually getting better gas mileage post SC than before... on the highway. 380-420 miles from a tank of gas with the cruise on 75ish. :wink:
Remember you are not in boost all the time.
06 DG G35 Sedan 6 MT
motordybe spacer|stillen tube|MRR GT 1 19x8.5,19x9.5 Toyo T1R's
wiz2
Postby Ian » Mon Nov 21, 2005 1:53 pm
I use mines as a daily driver, which means I log about 50 miles per day. Plus, I use it to drive from L.A. to Dallas (3,000 miles, 40hours, round trip) every year, sometimes twice a year.
It performs like a champ, and I see no need to worry. The long distances are just steady speeds of 80mph, or higher :), in 5th gear. There is no boost whine or anything special going on in 5th gear so there should be no fear of overheating. I only stop to gas up, then I'm back on the road.
I'm 6psi S/C for the past 3-4 years.
Ian
Postby DatSRBoi » Mon Nov 21, 2005 3:01 pm
Cool awesome.. Less worries for me haha.
Postby CASTRO » Mon Nov 21, 2005 3:06 pm
My car logged in about 146,000 miles before the s/c was put on. Now, @ two thousand miles later, Still no problems and going by my ODB2 sensor reader, temps actually go up in stop and go traffic vs. Highway driving. Freeway water temps sit at a nice 179-181*F (which is perfect for stock) and once the car stops or I hit a light, It gets as high as 190-198 depending on outside temps or how hard the car was run prior. I drive about 60miles a day round trip (school&work) no problems. Running 4psi with no EBC.
CASTRO
Postby Akfahad » Tue Nov 22, 2005 12:59 am
My car is a daily driver, got boosted in the spring of '04 when I was stationed in Alabama. Drove it to NC. I made a trip up to Vermont which took about 11 hours and had no problems. 6lb pulley went on afterwards and still no problems. Like Ian said, you'll have no problems SC'ing your car and having it as a daily driver.
Postby dominoSLEV6 » Tue Nov 22, 2005 1:12 am
Woah, did I miss something? How long have you been boosted datsrboi? :o
-chris
dominoSLEV6
Postby hskrsolara » Tue Nov 22, 2005 1:42 am
dominoSLEV6 wrote:Woah, did I miss something? How long have you been boosted datsrboi? :o
-chris
ditto!
hskrsolara
Postby ChargedSolara » Tue Nov 22, 2005 2:06 am
been driving it since 99, got 110k now. probably 50 of those were boosted. had several problems.
1.) tranny
2.) cel lights (various reason, similar to what most members experience)
this is at 5.5 psi, with minor mods.
the car has been running weak for a few months now, my best guess is compression is low.
2008 C6 LS3
ChargedSolara
Postby SC V6 » Tue Nov 22, 2005 7:39 am
I drive a few trips w\ my car... no problems here, and I did a tranny swap to go w\ it
SC V6
Postby dsmman » Fri Dec 02, 2005 11:26 am
Boosted for life of the vehicle & use as a daily driver. No worries or problems.
Twilight Blue 01'
6cly, 5spd, supercharged
Eibach 1.6
TRD short throw/strut bars
TRD exhaust
dsmman
Return to Forced Induction
