SolaraGuy.com • View topic - Dyno #'s...
Dyno #'s...
Postby BradOwens » Wed Nov 23, 2005 8:22 pm
nice numbers. im guessing ur boosted. wat other mods u got?
BradOwens
Re: Dyno #'s...
Postby SpeedSTARs » Wed Nov 23, 2005 9:31 pm
camry_y2k wrote:What kind of power did your cars put out?
Here is the dyno sheet:
http://solara.00server.com/photo3.html
I had mine dyno'd at back in June 2005:
WHP @ best 252.1 average 249.3 @111mph /6200rpm
WTQ @ best 227.9 average 226.4 @70mph /3897rpm
This is also posted on my CarDomain sight listed on the SIG below.
:drinking:
SpeedSTARs
Postby Akfahad » Thu Nov 24, 2005 3:43 am
I wouldn't upgrade your pulley without doing basic fuel upgrades. As mentioned tons of times before (I know, the search function leads you on for hours), you should get Jims Fuel Rail upgrade (at a minimum) and I'd highly recommend getting the 190LPH Walbro fuel pump and 310cc injectors. The engine isn't built for higher boost applications than just the basic 4psi at the stock level, so if you try to upgrade your pulley without upgrading your fuel, you'll screw up your engine, like others have done.
(Check out my "www" for dyno results).
Josh
Postby thakidd » Thu Nov 24, 2005 8:25 am
214.1 hp
210.7 ft-tq
4psi
greddy cat back
cai
jims fuel mod
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Postby Assyrian » Thu Nov 24, 2005 11:03 am
nice numbers! wow, if you're seeing numbers like that then the manuals must be close to 240 whp. s/c is starting to sound tempting
-Edgar
A noobie with an 02 SEV6 MTX
Assyrian
Re: Dyno #'s...
Postby thakidd » Thu Nov 24, 2005 11:28 am
camry_y2k wrote:Just dynoed my car recently and here are the numbers:
Peak HP = 192
Peak TQ = 184
what gear did u dyno ur car in.....
14.3@96 60ft 2.173
thakidd
Postby Akfahad » Fri Nov 25, 2005 12:13 am
camry_y2k wrote:
Akfahad wrote:I wouldn't upgrade your pulley without doing basic fuel upgrades. As mentioned tons of times before (I know, the search function leads you on for hours), you should get Jims Fuel Rail upgrade (at a minimum) and I'd highly recommend getting the 190LPH Walbro fuel pump and 310cc injectors. The engine isn't built for higher boost applications than just the basic 4psi at the stock level, so if you try to upgrade your pulley without upgrading your fuel, you'll screw up your engine, like others have done.
Josh
Thanks for the info, I've been away for a while and I see that lots of things have changed. How or where would I go to get Jim's fuel system upgrade, and where did you guys buy the pump and injectors?
Thanks for any info.
-Davor
Davor,
Jim's fuel rail upgrade, read this thread:
http://www.solaraguy.org/viewtopic.php?t=21630&highlight=jim
The 190LPH fuel pump you can get from URD for $90 (just do a search on the internet "URD")
Injectors, you'll have to call RC Engineering and tell them the engine you have. 318cc or 310cc will do fine. I know they have 370cc, but that's probably too much.
**Also, once you upgrade your pulley and slap on all those fuel upgrades, your going to need to put in premium gas all the time, no more regular**
Postby SpeedSTARs » Fri Nov 25, 2005 12:28 am
Josh
^^^ Yep I totally agree. :D
To add to list, you'll also need a Air Fuel Adjuster such as the Apexi Super AFCII or something of that nature. :wink:
SpeedSTARs
Postby Akfahad » Fri Nov 25, 2005 6:41 am
^^^ Very true, but I think you have the SAFC II, don't you Davor?
Postby scdsolara619 » Fri Nov 25, 2005 5:22 pm
I have been using Premium fuel ever since I had the car and I can swear that it feels like it pings at times... but I don't know.
P.S. This is my new user name, my old one (camry_y2k) is inactive suddenly for whatever reason...
Thanks for your help.
- Davor
02 SE V6 (S/C) AT
scdsolara619
Postby scdsolara619 » Fri Nov 25, 2005 5:29 pm
Akfahad wrote:^^^ Very true, but I think you have the SAFC II, don't you Davor?
I do have the SAFC but it is not tuned. I will have to do it once all these fuel system / pulley upgrades are done.
P.S. What is a good shop here in Southern Cali that has dyno tuned Solaras previously?
Thanks for the info.
-Davor
02 SE V6 (S/C) AT
scdsolara619
Postby gman » Fri Nov 25, 2005 8:33 pm
Davor- AS Josh the crazy dancer above alluded to...the rc injectors. Try and hit up trd4life to see if he has access to any more non-turbo Supra injectors, they are more plug and play and seat better in the head.
To reiterate- Definites are (if you go to 5.5)
93 octane
Safc tuned
injector upgrade
Jims
fuel pump
a high flow cat & catback would help get the heat away from the motor and out the back door faster. Our valve train and head were not designed to flow exhaust! Heat and lack of fuel is the enemy always remember that! One of the masters of this forum has just move onto bigger things....Joeb!! Do a search on his name and read as much of his stuff as possible, he is a wealth of knowledge and posted A LOT of stuff here.
Have fun and take every precaution to prolong the life of your motor
Peace
Gerard~
Grey Menace
gman
Return to Forced Induction
