SolaraGuy.com • View topic - Queeeeeestion
Queeeeeestion
Queeeeeestion
Postby dominoSLEV6 » Thu Nov 24, 2005 4:36 pm
I searched and can't find this answer. I know bits and pieces of it are scattered around the forum, but I can't track them down.
Exactly what components aside from the actual blower are needed for the supercharger install, where can onr get them, and how much are they usually?
I know some are available through Toyota, but I have no idea what would be needed outside of the idler plate assembly which is apparantly more difficult to find than a new TRD lip kit.
If one of you boosted cats could let me in on what parts are needed and a ballpark of the $ needed, I would much appreciate it.
-chris
dominoSLEV6
Postby SC V6 » Thu Nov 24, 2005 4:40 pm
you need the blower itself, EBC (electronic boost controller) and the idler kit.. the idler kit comes with the extra bolts you need... also a EGR tube
SC V6
Postby Paladin06Greg » Thu Nov 24, 2005 6:39 pm
Everything you need with PN's and tools.
Section 1: Installation Preparation
Kit Contents
Qty Description Connection or Installation Location Page Part Number
1 Supercharger/Manifold Assembly - Camry/Solara Main Assembly - Bolts directly to OE Manifold. 11 00646-17620-307
1 Supercharger Belt - Camry/Solara Replaces OE Alternator Belt. 15 00646-17620-330
1 Assembly, Idler Plate and Pulley - Camry/Solara Installed on front of engine. 14 00646-17620-320
1 Convoluted EGR Tube - 5 Speed Replaces OE EGR Tube. 10 17620-355
or Convoluted EGR Tube - Automatic Replaces OE EGR Tube. 10 17620-360
1 Kit, Literature
1 Manual, 3.0 Installation
1 Warranty Card Fill out and send in to TRD.
1 Warranty Certificate Keep in glove compartment.
2 Decal, Kazuma Place as desired. Usually placed on OE Timing Belt Cover.
1 EO Sticker Place underneath hood. 17
1 Belt Routing Sticker Place underneath hood. 17
1 Premium Fuel Sticker Place one on or near fuel gauge, the other inside fuel filler door. 17
Supercharger Brochure, Catalogs, Promo. Matl.
1 Idler Plate Installation Kit
2 Bolt, Allen Head - 10mm x 1.25mm x 30mm Attaches Idler Plate to engine. 14
1 Bolt, Counter Sunk - 10mm x 1.25mm x 100mm Alternator Pivot Bolt - Installed through Idler Plate and Alternator Pivot Bolt Spacer. 14
1 Spacer, Alternator Pivot Bolt Installed between Idler Plate and Alternator Pivot Mount. 14
1 Bracket, Drive Plate Attaches Idler Plate to engine. 14
1 Bolt, Counter Sunk - 8mm x 1.25mm x 20mm Used to attach Drive Plate Bracket to engine. 14
1 Washer, Flat - 8mm Used with 8mm x 1.25mm x 20mm Counter Sunk Bolts. 14
1 Nut, Nylock - 8mm x 1.25mm Used with 8mm x 1.25mm x 20mm Counter Sunk Bolts. 14
1 Bolt, Hex Head - 10mm x 1.25mm x 100mm Attaches Engine Moving Control Rod through Idler Plate and Gooved Pully. 16
1 Washer, Flat - 10mm Used with 10mm x 1.25mm x 100mm Hex Head Bolt. 16
1 Nut, Nylock - 10mm x 1.25mm Used with 10mm x 1.25mm x 100mm Hex Head Bolt. 16
1 Hose, Connector and Hardware Kit
2 Stud, 8mm x 1.25mm x 50mm Attach to bottom two holes on Supercharger Intake Plenum to mount Throttle Body Assembly. 13
1 Vacuum Hose - 5/16" x 13" long Connects PCV valve to Supercharger Assembly. 10, 11
1 Vacuum Hose - 3mm x 8" long Connects PWM VSV to Vacuum Control Tank (VCT). 13, 18, 19
2 Vacuum Hose - 3mm x 15" long One hose connects Vacuum Control Tank (VCT) to EGR valve and the other hose connects
Vacuum Control Valve (VCV) to Supercharger Assembly. 13, 18, 19
3 Hose Clips, Black Plastic Retains vacuum hoses in their proper places. 13, 18, 19
1 Valve, IAC, Check Installed near IAC valve. 7
2 Bolt, Hex Head - 6mm x 1.0mm x 18mm Attaches EGR valve to engine. 12
2 Washer, Flat - 6mm Used with 6mm x 1.0mm x 18mm EGR bolts. 12
2 Vacuum Caps Used to cap off Acoustic Control Induction System (ACIS) VSV and associated pipe. 13, 18, 19
1 90 degree elbow Attaches vacuum hose to EGR valve. 13, 18, 19
1 Barb, 1/8" 1 each placed in 90 degree elbow. 13, 18, 19
3 Large Zip Tie Used to tie engine main wiring harness to low pressure refrigerant line. 10
6 Medium Zip Tie 1 used to tie PVC hose to engine, 1 used to tie unused vacuum tank hoses to engine harness,
2 used to tie ground straps and coolant recovery hose to Engine Moving Control Rod
and 2 used to tie Vacuum Control Tank (VCT) to front of engine. 10, 13, 17, 18, 19
Miscellaneous
1 Strut Tower Brace Used only with Kits 00646-17620-301 and 00646-17620-302 17
Service Parts - not included as spare in kit.
2 per assy. Pulley and Bearing Assembly, Smooth For use as service items only. 00602-17620-019
2 per assy. Pulley and Bearing Assembly, Grooved For use as service items only. 00646-17620-325
Tools Recommended
Basic Tools Basic Metric Socket, Allen & Open-End Wrench Sets
1/2" Wide Masking Tape for Labeling Hardware and Parts
A Clean Work Bench
A Parts Tray
Rags or Shop Towels
Safety Tools Safety Goggles
Special Tools Tensionometer (available from Kent-Moore, 1-800-345-2233) See figure 48
Toyota Repair Manual (available from Toyota, 1-800-622-2033)
Accessories TRD shift control unit, part # 00646-17620-375
(Automatic transmission vehicles only)
Paladin06Greg
Torqued Solara
Torqued Solara
Postby dominoSLEV6 » Thu Nov 24, 2005 8:52 pm
Greg wins. :P just kidding, all help is apreciated.
Thanks for the in depth Greg.
-chris
dominoSLEV6
Re: Queeeeeestion
Postby Vampire » Thu Nov 24, 2005 9:23 pm
Here's a link to the TRD install manual that is in pdf format.
http://www.trdusa.com/InstallManuals/00 ... 20-3xx.pdf
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Return to Forced Induction
