SolaraGuy.com • View topic - Turbo
Turbo
Turbo
Postby woa_its_j3ff » Thu Dec 22, 2005 5:34 pm
anyone know if I can get a turbo for a 1999 Solara SLE V6?
just a thought, cuz I had a trd supercharger but sold that.. in hope of getting one.. :-\
any response would be greatly appreciated. thanks you guys.
and if I can get a turbo, about how much would that cost? (including like the blow off valve and turbo-timer etc..)
Thanks again.
Postby Assyrian » Thu Dec 22, 2005 5:47 pm
why on earth did you sell the supercharger? was it a full kit?
No company makes a full kit for the solara, as far as my research has taken me.... you'd have to fabricate the necessary pipes... which can be pretty costly.
-Edgar
A noobie with an 02 SEV6 MTX
Assyrian
Re: Turbo
Postby redkysolarase » Thu Dec 22, 2005 6:42 pm
woa_its_j3ff wrote:anyone know if I can get a turbo for a 1999 Solara SLE V6?
Thanks again.
If you find one out there then please let us know especially me cuz I'd much rather have a turbo instead of a supercharger. I love the sound of a blow off valve and I've heard that it gives you more power and even better gas mileage (please correct me if I'm wrong).
redkysolarase
Postby lilm » Thu Dec 22, 2005 6:45 pm
ya a turbo would be cool but not economical(?) cause you would have to fabricate EVERYTHING
lilm
Postby solaraslev67 » Thu Dec 22, 2005 6:46 pm
any turbo for a 1mz would have to be custom and shidosha is getting his done but it has definitely cost him an arm and a leg to do, you would have to talk to him about it but everything is custom, good luck and let us know what you are doing.
solaraslev67
Postby Mandarinsolara » Thu Dec 22, 2005 6:49 pm
you can do it if you want
buy 2 t3/t4's off ebay for $300 ea
two wastegates with 4-6psi springs
lots of pipe for your boost and intercooler pipes
one of those cheap large front mounts off ebay
apexi s-afc
apexi avc-r
and an AEM AFR meter
for under 2 grand you cant do much better
Mandarinsolara
Postby Turbosolara » Thu Dec 22, 2005 7:53 pm
Mandarinsolara wrote:you can do it if you want
apexi s-afc
apexi avc-r
if it is so easy, why dont you do it? :lol:
Postby Grazi07 » Thu Dec 22, 2005 8:08 pm
^ hahaha!!!
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby jhenty » Thu Dec 22, 2005 8:37 pm
You forgot the biggest part, adding fuel, new injectors, pump, ect. technically it is pretty easy, the hard part is the tuning. And as far as I know the solara has weak internals.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby BradOwens » Thu Dec 22, 2005 8:50 pm
yea dude just go with s/c. the turbo is a huge project. u should only do it if ur willing to spend the $$$
BradOwens
Postby Mole » Thu Dec 22, 2005 11:21 pm
start posting in the correct forums.
Postby lilmike2069 » Wed Jan 04, 2006 10:10 pm
Hey go with the turbo for 2 reasons:
1.) I think you'd have the ONLY solara with a Turbo (if you do one you might as well go twin turbo ;)
and
2.) Turbo's are more efficient than a supercharger because a supercharger has a belt that is mechanically taking power from the system before it puts back in... A turbo uses the exhaust which is wasted anyway.
lilmike2069
Postby Mandarinsolara » Wed Jan 04, 2006 11:24 pm
lilmike2069 wrote:2.) Turbo's are more efficient than a supercharger because a supercharger has a belt that is mechanically taking power from the system before it puts back in... A turbo uses the exhaust which is wasted anyway.
exactly
http://www.solaraguy.org/viewtopic.php?t=17456&start=0&postdays=0&postorder=asc&highlight=
Mandarinsolara
Postby jhenty » Thu Jan 05, 2006 12:23 am
yes but turbos produce more heat and are proven typically to make a cars engine less reliable than a supercharger. They each have there benefits and downsides but it comes down to what you want to do with it.
1990 BMW 535i
jhenty
Postby DatSRBoi » Thu Jan 05, 2006 1:03 am
Supercharger=Low end power
Turbo=High end power
Supercharger, Better for take offs and city driving
Turbo, Better for highway or cruising power.
Efficiency= Depends where and when you use it.
Engine life, Boost kills, no matter if its alittle or allot. 1 lb of boost will kill and engine faster then no lb of boost.
Must I add track racing dont like turbos as much. Unless its small ones. Because extent use of turbo causes the motor to loose power in long cuircut racing.. UNLESS its only small turbos. Like rally racing. Not allot of Hp or major turbo. Because they have downfalls. A supercharger was meant for low power and mid power, but will lag high power a bit due to its maximum run turns.
Thats why all motor rules if you can built it right.
Return to Forced Induction
