SolaraGuy.com • View topic - Dats Boost pulley question and gauges?
Postby DatSRBoi » Sat Dec 31, 2005 3:12 pm
Ok Ok. I read a few post awhile back about members having boost gauge issues and how they resolved it. Well I finnally hooked up my boost gauge today and at idle its on VAC 20! Which Im guessing is normal and pass 20 is too much.When I floored it, it only said 2 to 3 at most PSI Boost. I have a PSI gauge not bar gauge and everything is tightened. I was told I have a 4psi pulley by the guy in this forum who sold it to me... But on the pulley it says TRD 3.4.
Whats going on? Is this why Im loosing to cars I shuold be close to?
This is the gauge I have.
Postby dominoSLEV6 » Sat Dec 31, 2005 8:28 pm
May friends procharged mach 1's boost gauge reads quite a bit of vaccum too at idle. His pulley was supposed to be 8 lbs but he was only registering about 5.5, somtimes there's issues with things like that, I don't think there's such thing as a 1/2 psi pulley, lol, but anyway maybe the ocnnection is just a little bad or something I think that was the problem with his I don't know if he's gotten it fixed yet, but I wouldn't panic over it.
-chris
dominoSLEV6
Postby DatSRBoi » Sat Dec 31, 2005 9:46 pm
Ok I read it wrong. Its going up to the second mark which means 3PSI... But it only gives me that in pass 5,000RPM I think. Somewhere around there..
The pulley has these letters and numbers on it. TRD-3.4 .... Does that mean I only get 3.4 PSI? What happen to the 4 :(
Can someone teach me these numbers again?
Postby CASTRO » Sat Dec 31, 2005 11:42 pm
ive got me a TRD pully that reads 3.2inches. I read somewhere that they used a slightly smaller pully for more power but didnt rename the PSI
CASTRO
Postby Akfahad » Sun Jan 01, 2006 4:37 am
I had the same experience when I changed my stock pulley to a 6lb pulley. It said "TRD 3.4," same as you DAT. My first reaction was WTF too, but I went off of what my boost gauge told me and whenever I floored it, it always read 4lbs. I didn't really think anything else about it since I was changing pulley's, but I would still like to know too.
Postby dominoSLEV6 » Sun Jan 01, 2006 7:46 am
More about my buddy's mach FWIW, he doesn't make boost without WOT.
-chris
dominoSLEV6
Postby DatSRBoi » Sun Jan 01, 2006 8:23 am
TRD 3.2" -------------2.5 - 3 PSI
3.0" -----------------
2.9" ------------------5.5 PSI
2.8" ------------------6 PSI
2.7" -----------------
2.6" ------------------7 PSI
2.5" ----------------
2.4" -----------------8 PSI
This is what I found at some site. Even then Mines says 3.4 and boosting only 3psi.
Postby eyedea » Sun Jan 01, 2006 10:51 am
You are right. when I installed my supercharger. I went straight to the 5.5 pulley, which indeed does read 5.5 lbs of boost at max. Due to unavoidable circumstances, i had to switch back to the stock SC pulley..(the "key" on the SC which i bought used wore out...)..
My TRD boost gauge cannot be wrong for the max boost is around the 3-3.3 lb range...
5SP 02 SE V6 SC 1MZFE .......RIP ...
2003 Infiniti M45 =340hp of RWD sex
eyedea
Postby DatSRBoi » Sun Jan 01, 2006 7:31 pm
eyedea wrote:You are right. when I installed my supercharger. I went straight to the 5.5 pulley, which indeed does read 5.5 lbs of boost at max. Due to unavoidable circumstances, i had to switch back to the stock SC pulley..(the "key" on the SC which i bought used wore out...)..
So your gauges are telling you the right boost right?
Postby eyedea » Sun Jan 01, 2006 11:08 pm
Yes. The so called 4lb pulley registers much less boost than 4 at full throttle..
eyedea
Postby DatSRBoi » Sun Jan 01, 2006 11:21 pm
Dam... Time to find me a 5psi or 5.5 pulley... 3 isnt cutting me much.
Postby thakidd » Mon Jan 02, 2006 9:37 am
mine reads 4 on my trd gauge.i have a 6lb pulley if u want it dat...
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Postby DatSRBoi » Mon Jan 02, 2006 10:33 am
No thanks I pass on that. 6PSI is too risky. I want to, but haha The pain to tune and keep it safe is too expensive for me right now.
Postby 808Camry » Tue Jan 03, 2006 5:12 pm
What size fitting did you use, I still haven't hooked up my boost gauge yet.
808Camry
Postby CASTRO » Wed Jan 04, 2006 11:31 am
My 3.2 TRD stock pully reads exactly 4psi on the TRD gauge I have. Going with the EBC and updated hosing it bearly touched 4psi at high RPM.
After I bypassed the EBC by re-doing the hoses straight to the actuator, I can hit 4psi and sometimes it spikes to 4.5 easily.
Read up on Astro's problem about the actuator staying partially open at WOT. I believe he said something about getting only 85% boost.
CASTRO
Return to Forced Induction
