SolaraGuy.com • View topic - TRD SC & CAI DONT WORK?
Postby DatSRBoi » Thu Jan 05, 2006 2:22 pm
I was reading this one manuel and it say qoute
" Caution: do not use any aftermarket "cold air intake" kits with the TRD supercharger. The oe air filter hoursin and the or mass air flow sensor are cirtical for the correct air/fiel ratio calibration with the TRD supercharger. Etc Etc"
Source here......
http://www.trdusa.com/InstallManuals/00 ... %20Pulley'
So now would that mean its better to keep ram air and not cold air? Could cold air really ruin the cars MAF sensor and throw the car off track and tune?
Makes me wonder if ram air nor cold air intake be safe with the supercharger.
Postby Mandarinsolara » Thu Jan 05, 2006 3:00 pm
no it cannot ruin the maf sensor, but bc of the intake volume change, there will be a change to the tune of the car, but the car is designed to compensate for the difference and handle it
Mandarinsolara
Postby indiglosolara » Thu Jan 05, 2006 3:34 pm
Even thought i'm not boosted.. With the Injen SRI i was running more lean than with the stock air box with k&N or TRD filter.
This can be dangerous depending on your situation. I still have the Injen installed but i plan on taking it out sometime soon.
I really lost allot of Low end power with the Injen.
Running lean can be a bad and good thing depending on your set-up.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby DatSRBoi » Thu Jan 05, 2006 4:21 pm
indiglosolara wrote:Even thought i'm not boosted.. With the Injen SRI i was running more lean than with the stock air box with k&N or TRD filter.
Yeah Im kind of reading up about that. Our sensors arnt the MAP sensors so MAF would throw the reading off on a bigger pipe intake aka aftermarket. I also notice the designs of our specific MAF sensor arnt really strong. Running boost must put allot of stress against the sensor.
Postby indiglosolara » Thu Jan 05, 2006 5:30 pm
Yup, Thats why some have gotten the CEL with just intakes. Some have been lucky. I've gotten the CEL light with my Injen once. I floored it on the freeway and the CEl came on. I got a reading and it was the MAF Malfunction. I just resetted the code and it never came back. But then again i haven't really floored or took my car to more then 4500 rpms at all recently.
But just to be on the safe side i'm putting my stock airbox back in with the standard TRD filter.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby bunthy » Thu Jan 05, 2006 6:26 pm
I never got a CEL with it on....
btw whats MAP and MAF stand for?
bunthy
Postby jhenty » Thu Jan 05, 2006 10:52 pm
this is a problem that can be solved with tuning, such as the apexi afc. The solara is not designed to compensate for this much difference in air.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby DatSRBoi » Thu Jan 05, 2006 11:32 pm
jhenty wrote:this is a problem that can be solved with tuning, such as the apexi afc. The solara is not designed to compensate for this much difference in air.
Yeah true. But thats allot of money we're talking here even though yeah yeah money=power..Just saying so. But Im still thiking thats allot of stress on the small sensors.
MAP=Mass air pressure. This is what gives honda quick power without CEL
MAF=Mass air flow.... This is the one that doesnt like aftermarket parts with CEL
Postby jhenty » Fri Jan 06, 2006 3:26 am
your right dats, it may end up being expensive. Im not sure of a real solution, I dont know how hard tuning is to know if its something one could do theirself. What about the vortech FMU?
1990 BMW 535i
jhenty
Postby Mandarinsolara » Fri Jan 06, 2006 6:07 am
lol
it stands for
Manifold Absolute Pressure, aint you ever heard of a honda
HKS VPC kit is the only way you can get something close to a MAP sensor on a toyota
Mandarinsolara
Postby Wang2k » Mon Jan 30, 2006 6:13 pm
lol mass air pressure :lol:
Wang2k
Postby Wang2k » Mon Jan 30, 2006 6:18 pm
So hondas are speed density systems? That would actually hinder them wouldnt it because they are very sensitive to vacuum changes and such...It doesnt really measure the air coming into the engine it just knows the vacuum and percent of throttle opening, engine speed, etc and uses a program to figure out the amount of fuel the engine needs.
MAF knows how many grams of air are coming into the engine, along with the tps and rpms..this style can take a lumpier cam and sing with it because its not limited to a stock program..
Right or wrong?
Wang2k
Postby RedPhoenix » Sat Feb 25, 2006 11:03 am
you could get a engine management that rids the MAF. expensive, but the MAF is a pain in the ass. Im glad my 5sfe uses MAP, but I know my Greddy Ultimate has the ability to convert MAF to MAP with a new sensor. A lot of Supra guys are loving this.
5SFTE Coming soon.
RedPhoenix
Return to Forced Induction
Users browsing this forum: No registered users and 76 guests
