SolaraGuy.com • View topic - Vaccum Tank ports, capped ?
Postby bunthy » Fri Jan 27, 2006 7:04 am
Hey all,
My question is in the pix:
If their not capped, then where do they attach to?
Thanks.
Bunthy
bunthy
Re: Vaccum Tank ports, capped ?
Postby Vampire » Fri Jan 27, 2006 2:23 pm
Is that for your Avalon? On the Solara, the vacuum tank is under the battery tray. It's supposed to be used as a vacuum reservoir for the EBC system. It provides a reserve vacuum source for the EBC actuation of the bypass valve. If you do not use the EBC, then it's just capped off at the tank or the vacuum lines are plugged.
bunthy wrote:Hey all,
Thanks.
Bunthy
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Postby bunthy » Sat Jan 28, 2006 5:58 am
yeah, I'm using the EBC now, but the tank is either capped off nor connected to anything else. I followed the diagram to the best of my knowledge. In the diagram, where they show the new connection to the vacumm tank, I did do that. Bu the tank itself is uncapped near the firewall. Any clue?
bunthy
Postby Vampire » Sun Jan 29, 2006 2:01 am
On an Avalon is that thing really between the firewall and motor like in your pic? You got a service manual or can post a pic? Maybe Jim knows. I have never seen under the hood of any Avalon.
bunthy wrote:yeah, I'm using the EBC now, but the tank is either capped off nor connected to anything else. I followed the diagram to the best of my knowledge. In the diagram, where they show the new connection to the vacumm tank, I did do that. Bu the tank itself is uncapped near the firewall. Any clue?
Paul
Vampire
Return to Forced Induction
