SolaraGuy.com • View topic - Nitrous on a BONE STOCK 2000 V6???
Postby 1quickgt » Fri Feb 24, 2006 8:43 am
Has anyone ran nitrous through a BONE stock Solara V6 AUTO.
I'm trying to look into this, but can not find anything.
Thanks
1quickgt
Postby SolaraBlue » Fri Feb 24, 2006 9:15 am
lol why would you want to?
Postby 1quickgt » Fri Feb 24, 2006 9:26 am
To see what it can do. Plus warranty is still there and I am the mechanic for the dealer.
00 Solara SLE V6 - Stock
1quickgt
Postby returnofthedack » Fri Feb 24, 2006 9:29 am
damn man he just asked a simple question when he said "why would you want to" cause it might blow the engine, and if you wanna do jerk off signs and since you talk about how your a mechanic, wouldnt you realize that they never made an XLE v6 and it was an SLE v6 for the solara?
www.seandackermann.com
The only person that can stop you in life, is yourself
returnofthedack
Postby 1quickgt » Fri Feb 24, 2006 9:49 am
lol
No crap it might blow the motor, but i was seeing if there is a certain level until they do max
1quickgt
Postby Wang2k » Fri Feb 24, 2006 10:04 am
You are not a mechanic...mechanics dont ask questions like that...they research the subject using the wealth of information available to them...its obvious you are full of doo. I on the other hand am a mechanic, and I can smell bullshit from a mile away. So your a nothing that wants to put nitrous on his AUTO solara(i know there are some out there) First mechanic replace your pistons and rods as the stock pistons have almost no meat because they made the area abouve the top ring land very thin to reduce hydrocarbon emissions, then come back and I will tell you the next step, as im sure you have no clue
I have seen stock high mileage 1mz's break pistons just like the supercharged cars do(my engine had 1 broken piston that i didnt even know about till i tore it down, and so did the engine in a friends es300(3 chipped pistons), so these pistons are really really weak.DO NOT SPRAY THEM UNLESS YOU LIKE DROPPING THE CRADLE
People think they are mechanics if they can replace drum brakes.. :roll:
Wang2k
Postby Fletch » Fri Feb 24, 2006 11:29 am
Several people have run nitrous on stock AT 1MZ's. I am positive I have read some posts, you should find them if you search the right keywords, try V6 Camry also.
The piston lands seem to be the weakpoint in the stock motor. It does not like high boost.
2006 Legacy GT spec.B
Fletch
Postby 1quickgt » Fri Feb 24, 2006 12:20 pm
Fletch wrote:Several people have run nitrous on stock AT 1MZ's. I am positive I have read some posts, you should find them if you search the right keywords, try V6 Camry also.
thanks
1quickgt
Postby lilm » Sat Feb 25, 2006 2:26 pm
Wang2k wrote:You are not a mechanic...mechanics dont ask questions like that...they research the subject using the wealth of information available to them...its obvious you are full of doo. I on the other hand am a mechanic, and I can smell bullshit from a mile away. So your a nothing that wants to put nitrous on his AUTO solara(i know there are some out there) First mechanic replace your pistons and rods as the stock pistons have almost no meat because they made the area abouve the top ring land very thin to reduce hydrocarbon emissions, then come back and I will tell you the next step, as im sure you have no clue
lol someone woke up on the wrong side of the bed.......
searching is the way to go :drinking:
lilm
Postby thakidd » Sat Feb 25, 2006 3:09 pm
if i was gunna run juice in my car i wouldnt go more than a 75shot just like a few posts above the ringlands are pretty week......
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Postby Wang2k » Sun Feb 26, 2006 8:37 pm
i apologize for that i wasnt all there when i posted :fadein:
Wang2k
Postby sydemoid » Sun Feb 26, 2006 9:10 pm
My honest opinion, based on pass experience with NOS...
on a stock mill.... dont do more than a 50 shot, it may handle a 75 shot, but you are going to kill the longevity of the internals.
Im not a mechanic by any means, but I have anough common sense to listen to other people who go thru stuff...
If you want my opinion.... port the heads, stiffen the valve srping a bit, get forged pistons, and bore out the block .20
Balance the crank, get beefier connecting rods... andmake sure you get an oil cooler.
Run that naturally aspirated, keeping the stock piston ceiling clearances...
I dunno... Im ranting about.... if this makes sense, someone please let me know...
sydemoid
Postby 1quickgt » Mon Feb 27, 2006 2:53 pm
Thanks. I have a kit already from another car, gonna hook it up this weekend w/ a 50 shot and put it on the dyno....
I dont want to build a motor, i have others car for that, lol
1quickgt
Postby PASolara » Sat May 06, 2006 7:56 pm
All most at 2 years on the Bottle for me :drinking:
Stock Internals and a 100 shot
PASolara
Return to Forced Induction
