SolaraGuy.com • View topic - Another Wiring EBC Quesiton
Postby bunthy » Fri Mar 03, 2006 9:56 am
hey guys,
I'm THIS close to figuring out where the EBC goes on my avalon! I've a question though about 2 of the wires from the EBC.
This is from the instructions for the ALL 1997 AND NON-CA SPEC 1998 W/AT:
The PURPLE connects to E 10 Pin 11
and
The BLUE-BLACK(WHITE-BLUE) connects to E10 Pin 17
These two Pin on E10, I cannot find in the 97 electrical diagram, taken from Zoni's webpage :
http://zonicamry.com/Info_and_Tech_Docu ... mz_ecu.pdf
In that diagram, there is NO Pin 11 & Pin 17 on E10. Where did you guys wire them to? What are the colors? If you have a diagram for it, that would be great. And if I can't find it, can I wire them pin like the MANUAL EBC(i.e. grounding both wires)????
Thanks - Bunthy
bunthy
Postby krook » Fri Mar 03, 2006 1:12 pm
that diagram looks really complicated. when i installed mines we all used this diagram per "happyaggies":
krook
Postby bunthy » Sat Mar 04, 2006 12:16 pm
thanks, I'll see what I can do with that.
bunthy
Return to Forced Induction
