SolaraGuy.com • View topic - upgraded pulley shall slip NO MORE
Postby krook » Wed Mar 08, 2006 5:44 pm
i upgraded to a 2.7 pulley (i think that's the right part #, sheeez i don't even remember..!) a looooong time ago and i never bothered to change my SC belt. when i finally got the correct belt size, i learned that other members were having trouble with the upgraded boost blowin' knock sensors. so i stopped there. with the smaller pulley on my SC. all these months/years. the problem was/is that the stock SC belt my charger came with slips once in a while, and vibrates LIKE HELL!
sooo anyway, i'm ready to make all the necessary adjustments to accomodate my smaller pulley. i'm gonna git the Fuel Upgrade Kit from URD, is there any thing else i should be looking into???
krook
Postby CASTRO » Thu Mar 09, 2006 2:05 am
get GM knock sensors and wrap them using dynomat.
CASTRO
Postby ruffrydasean » Thu Mar 09, 2006 5:14 am
Didn't we have to have the block rethreaded though for that? and how much do GM knock sensors run?
Click Pic for link to my Cardomain page.
Image]
ruffrydasean
Postby Akfahad » Thu Mar 09, 2006 9:57 am
you already have Jim's Fuel Rail Upgrade?
Other than that, you should be all set if you get that entire package. Can't remember exactly what it all comes with, but as long as you got bigger injectors, fuel pump, "colder" spark plugs, and some kind of computer (SAFC), you'll be good.
Postby CASTRO » Thu Mar 09, 2006 11:14 am
the URD package comes with all of that.
As for the GM knock sensor, it will fit as long as you have the adapter which comes with the kit provided by ATS. Dats confirmed that they fit w/o any rethreading, but its a tight fit.
CASTRO
Postby krook » Thu Mar 09, 2006 1:18 pm
CASTRO wrote:^
i'm a little rusty... where do i get Jim's fuel upgrade at? (website)
and i looked up ATSracing.com, but i couldn't find any GM knock sensors. what if i just went w/o the knock sensors?
was that just a dumb question . . .?
krook
Postby Yanks0114 » Thu Mar 09, 2006 3:06 pm
Jims fuel upgrade can be bought directly from Jim @ Foreignaffairs.
Postby Yanks0114 » Thu Mar 09, 2006 3:09 pm
Foreign Affairs Automotive Service
2315 SE 11th Avenue
Portland, Oregon 97214
(503) 236-2871
Postby CASTRO » Thu Mar 09, 2006 8:34 pm
krook wrote:
CASTRO wrote:^
heres what I got..
http://www.twosrus.com/new/Lower_Frames ... sknock.htm
CASTRO
Postby DatSRBoi » Thu Mar 09, 2006 8:41 pm
Yep yep. Just make sure you torque them down right and recomend you solder it in. Im going back to redo mine just in case.
Postby ruffrydasean » Thu Mar 09, 2006 11:12 pm
OK, cuz my light has been on for awhile... :(.. I'll get those ASAP...
Image]
ruffrydasean
Postby krook » Mon Mar 27, 2006 12:28 pm
okay, since i have a v6, i'll need 2 of those right?? (just double checking)
krook
Postby CASTRO » Mon Mar 27, 2006 1:04 pm
yup, its good to get 2 just for the sake of keeping things close to a stock setup
CASTRO
Re: upgraded pulley shall slip NO MORE
Postby QuickSEV6 » Mon Mar 27, 2006 2:28 pm
krook wrote:i upgraded to a 2.7 pulley (i think that's the right part #, sheeez i don't even remember..!) a looooong time ago and i never bothered to change my SC belt. when i finally got the correct belt size, i learned that other members were having trouble with the upgraded boost blowin' knock sensors. so i stopped there. with the smaller pulley on my SC. all these months/years. the problem was/is that the stock SC belt my charger came with slips once in a while, and vibrates LIKE HELL!
I have to ask. What belt did you get? I hear that the Dayco Polycog belt is the best. Just curious what size you got.
Postby krook » Mon Mar 27, 2006 3:24 pm
with my awesome searching skills i was able to pull up this post from Steve C. from 2003:
SC V6 wrote:its a Dayco Polycog... its different than the stock TRD sc belt... its suppost to grip a lot better.... Jim@foreign recommended it.. but it has 2 barcodes... one is 5060880, and the other is 6pk2235... I think u need te 6pk2235,,, but im not sure.. later
Scott
i remember i called my local auto parts store and asked them to fetch me a Dayco Polycog belt no. 5060880...i still have that sucker in storage awaiting install. :|
krook
Return to Forced Induction
