SolaraGuy.com • View topic - SUPERCHARGER WOES NEED HELP!
Postby solow1605 » Sat Mar 18, 2006 6:16 pm
Ok so i just bought a supercharger from another member on the forum and we were trying to get the kit off, but there's a problem. Theres a bolt going thru the alternator on the passenger side of it that is stripped. On the other side of the alternator is a 19mm bolt. My question is it the same screw going all the way thru thats connected to the 19mm bolt or are they two different things?
2003 Anniversary Edition z06. Black on black...seeexxy
solow1605
Re: SUPERCHARGER WOES NEED HELP!
Postby DatSRBoi » Sat Mar 18, 2006 6:20 pm
solow1605 wrote:Ok so i just bought a supercharger from another member on the forum and we were trying to get the kit off, but there's a problem. Theres a bolt going thru the alternator on the passenger side of it that is stripped. On the other side of the alternator is a 19mm bolt. My question is it the same screw going all the way thru thats connected to the 19mm bolt or are they two different things?
Dam that sucks good luck man.
Postby JavaJoe_2 » Sat Mar 18, 2006 6:37 pm
I don't know if you have the install manual, but here it is:
Install Manual
Got Boost?? :sweet:
JavaJoe_2
Postby siennasc98 » Sat Mar 18, 2006 7:35 pm
That 19mm hex (head) is the nut ( and also as a bushing) for the alternator pivot bolt, though you cannot turn it because it's being blocked by the alternator casing. See attached picture here: http://photobucket.com/albums/d22/SiennaSC98/TRD%20Bolts/?action=view&current=DSC05682.jpg
siennasc98
Postby I4 to V6 Swap » Sat Mar 18, 2006 11:31 pm
If I understand what you are describing correctly, the bolt should be one piece. That should be the pivot point for the alternator. I could be wrong though.
I4 to V6 Swap
Postby siennasc98 » Sun Mar 19, 2006 12:12 am
I4 to V6 Swap wrote:If I understand what you are describing correctly, the bolt should be one piece. That should be the pivot point for the alternator. I could be wrong though.
Yes, the bolt is one peice. You can see how it looks like here:
http://photobucket.com/albums/d22/Sienn ... adBolt.jpg
siennasc98
AWESOME
Postby solow1605 » Sun Mar 19, 2006 9:56 am
haha great, thanks guys. The little piece thats supposed to keep the hex from shifting got grounded off by the shop, who's the reason we're having problems to begin with. So hopefully everything will work out and i'll be boosted by the end of the day. Thanks for the help guys!
solow1605
Return to Forced Induction
Users browsing this forum: No registered users and 64 guests
