SolaraGuy.com • View topic - NEED ENRICHMENT!
NEED ENRICHMENT!
NEED ENRICHMENT!
Postby Wang2k » Mon Mar 27, 2006 8:28 am
I am needing a FTC or AFC or EMS or what the hell ever asap. I am about to purchase a 2" pulley from Greg(F the BS 5.5 lbs) Could someone tell me which system works the best on our platform? I would not mind going full stand alone...which one works? Also the SS FTC looks enticing...Would their be much of a benifit over the SAFCII??? thanks
Wang2k
Postby Wang2k » Mon Mar 27, 2006 8:37 am
maybe the ESC1? thoughts good or bad? Also has anyone read the tuning guide on URD's website??? I found it to be very informative and i will be doing my own street tuning
Wang2k
tuning
Postby trd4life » Mon Mar 27, 2006 9:23 am
You have lowered compression right? Get an SAFC as well as an esc1(the esc1 puts you in open loop at 1psi), and a set of 330cc supra injectors from me. Have you got the fuel pump yet? You going ot need that as well.
The 2" pulley is way too small. You will be spinning the supercharger way out of its efficiency range, basically just blowing hot air into the motor promoting detonation. I would not go an smallewr than the 2.2" which is what i am running on my solara. If you are dead set on the 2" pulley, het a methanol injection kit or a nitrous kit to spray into the blower to cool things down
Postby Wang2k » Mon Mar 27, 2006 9:51 am
thanks, I have a universal wet kit that i have been aching to put on something, it shouldnt take more than a 30 or 40 shot to cool things down right? What shot are you running on the Red Knight? My compression ratio is 9.5:1 not the stock 10.5
Also after reading the posts on alc...i decided its not very effective...i mean true, if it is evaporating in the supercharger it is helping draw out heat, but I would like to see something a little more effective, but nitrous increases cylinder pressure a great amount....i am just now getting started on my car i would hate to have to drop the cradle again with a smoked engine...i may just get a 10lb pulley and shoot a 50 shot
Wang2k
great idea
Postby trd4life » Mon Mar 27, 2006 3:46 pm
Great idea do a 50 shot. With boost and juice the walbro 190 pump wont be enough, you need a walbro 255 high pressure part # gss341.
I have 9:1 compression on my solara.
Make SURE you get the bigger injectors before even thinking about that 10lb pulley.
Return to Forced Induction
