SolaraGuy.com • View topic - Tuning questions
Tuning questions
Tuning questions
Postby Grazi07 » Mon Mar 27, 2006 9:21 pm
In my possession right now are 318cc injectors, the 190 lph fuel pump, Gabe's TT MAF, and an S-AFCII, and a partridge in a pear tree. I know that to run these efficiently, a full out tuning is needed, but in the meantime can I run these with the 6 lb pulley safely?
I've never used an S-AFCII, any advice?
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
tuning
Postby trd4life » Mon Mar 27, 2006 9:36 pm
Bring it to a dyno after everything is installed see where your air fuel ratio is at.
Postby Akfahad » Tue Mar 28, 2006 7:00 am
I wouldn't. Leave the 4lb. pulley on there until you can get to a dyno. Let them put the pulley on and dyno it from there.
Postby Grazi07 » Tue Mar 28, 2006 8:23 pm
so what is needed to safely run 6psi?
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby CASTRO » Wed Mar 29, 2006 12:55 am
i'd say that i'd be best to do a return style gas line that Jim mentioned
CASTRO
Postby Ian » Wed Mar 29, 2006 7:07 am
Grazi07 wrote:so what is needed to safely run 6psi?
I run very safely with:
URD fuel pump upgrade
Jim's fuel kit
(injectors are stock)
I guess it depends on what your goals are as to whether you want to add an S-AFC or a Split Second unit to tune. For me, I just wanted my car to run safely (ie. have enough fuel output) given the addition of my 6psi S/C and CAI. It runs smooth and has very good pickup. I recently added the fuel pump and that smoothed out the slight sputtering in acceleration that I used to have.
Ian
Postby Grazi07 » Wed Mar 29, 2006 5:28 pm
Thanks guys for the info. So its really the injectors and the MAF that require the tuning? I'm a 4psi now with Jims mod and I'm sitting on the walbro 190 lph pump... anyone else have similar mods to Ian?
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby Akfahad » Wed Mar 29, 2006 5:34 pm
Ian and I have basically the same setup (except he chose not to upgrade his injectors). Personal choice I guess...from what I hear the injectors seem to do an ok job with the extra demand, according to Jim (I think that's who was talking about it, correct me if I'm wrong). You'd be all right installing the fuel pump and getting to a dyno later, that's what I did and didn't have any problems, of course I was running extremely rich when I did the dyno, but I also had injectors too.
Josh
Postby thakidd » Thu Mar 30, 2006 1:48 pm
andy i ran 5.5psi with just the 190 pump no tune and i was fine......
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Postby krook » Thu Mar 30, 2006 2:21 pm
so getting the injectors is not necessary then? is that correct? i remember hearing that from someone here.
if that's the case i should be safe just getting the URD fuel pump (NOT the whole kit) and Jim's fuel kit???
krook
Postby thakidd » Thu Mar 30, 2006 2:38 pm
krook wrote:so getting the injectors is not necessary then? is that correct? i remember hearing that from someone here.
i was fine with that and now im gunna go 6psi and now i have safc2 im just gunna get a quick tune....
14.3@96 60ft 2.173
thakidd
Postby krook » Sat Apr 01, 2006 5:31 pm
what about the URD thermostat? do you need to purchase this, too?
krook
Postby Grazi07 » Mon Apr 03, 2006 8:17 pm
I'm looking for the wiring diagram for the S-AFCII... the manual doesn't list the solara/camry/scepter platform, anyone know which diagram to use?
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby DatSRBoi » Mon Apr 03, 2006 8:23 pm
I got one. Posted it up on page two
Postby krook » Mon Apr 03, 2006 8:23 pm
i posted this a month ago:
krook wrote:that diagram looks really complicated. when i installed mines we all used this diagram per "happyaggies":
krook
Return to Forced Induction
