SolaraGuy.com • View topic - Stock boost runs Lean Bank 1 & 2?
Postby DatSRBoi » Thu Mar 30, 2006 9:08 pm
I received a check light today and thought I get it check out. The guy said it was throwing code that I was running lean in Bank 1 and 2. He didnt tell me the code and thought he was smart but I showed him. Anywho...... Running lean part. Why am I running lean in bank 1 and 2..
Mods--Injen SRI, Tanabe Catback and Y pipe. Gutted cat., GM knock sensor, 4psi supercharger, 190walrbo, and jim fuel mod with NGK BKR6EIX-11 NUMBER 3764...
What is the issue? I have a SAFC2 but not installed yet since I want to know is something wrong. Dont want to have to retune.
codes
Postby trd4life » Thu Mar 30, 2006 9:35 pm
Dat, you probably have a vacuum leak somewhere. Check your vacuum hoses. Or, you may be not be getting enough fuel. Hook up the safc and bring it to a dyno!
Re: codes
Postby DatSRBoi » Thu Mar 30, 2006 9:43 pm
trd4life wrote:Dat, you probably have a vacuum leak somewhere. Check your vacuum hoses. Or, you may be not be getting enough fuel. Hook up the safc and bring it to a dyno!
I hope Im not getting a leak. I hear a clicking sound when ever I step on the gas to accelerate around the throttle valve area.
Postby Mole » Thu Mar 30, 2006 10:31 pm
does jim's mod involve bigger injectors?
Race
Postby JMSinMaryland » Thu Mar 30, 2006 10:37 pm
Best to take it to the track and run it for an evening first, then go dyno tune it. Who cares about CEL's right? They're just created by the manufacturer to keep you coming back to the dealer. Your car sounds like it's finally running right. :roll: .
JMSinMaryland
Re: Race
Postby DatSRBoi » Thu Mar 30, 2006 11:08 pm
JMSinMaryland wrote:Best to take it to the track and run it for an evening first, then go dyno tune it. Who cares about CEL's right? They're just created by the manufacturer to keep you coming back to the dealer. Your car sounds like it's finally running right. :roll: .
Fuu shut up if your mocking me. You make me want to bust a flippin Cap on your ass. And I aight flippin kidding. I am not scare of your dam flippin smart talk mamas. Either help or shut the screw up bitch. If I ever see you in real life and you say crap like that. I will not just Bust a Cap on your ass, Ill also shove you own ride up your flippin ass.
Postby that1mexguy » Thu Mar 30, 2006 11:25 pm
^^ LOL
that1mexguy
Postby jhenty » Fri Mar 31, 2006 1:25 am
damn man, one of these days i better see dats finally got it running right. Everytime i read your posts I wonder what problems I have to look forward to in about a month. Good luck.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Re: Stock boost runs Lean Bank 1 & 2?
Postby StockSolara » Fri Mar 31, 2006 2:14 am
DatSRBoi wrote:I received a check light today and thought I get it check out. The guy said it was throwing code that I was running lean in Bank 1 and 2. He didnt tell me the code and thought he was smart but I showed him. Anywho...... Running lean part. Why am I running lean in bank 1 and 2..
It might be your intake cause that was happening to Simon and it won't stop coming back on even when his car was tuned
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
FOB mother f-er
Postby JMSinMaryland » Fri Mar 31, 2006 5:11 am
If I ever see you Im going to steal your Solara, sell it and buy you the whole hooked on phonics series. Your car 'tuning' skills are as bad as your english. Jon. p.s. if I ever saw you I'd drive your own car up your ass....that's if I could get it to run. :lol:
JMSinMaryland
Postby DaveMush » Fri Mar 31, 2006 6:28 am
Guys, there may be a problem that you all havnt researched much on these boards....
A couple guys on the mr2oc.com boards have swapped their cars with 1mz v6 engines... Myself included.
anyhoo...
Mitch and Mike had both purchased OBDII readers to monitor their fuel trims. Mike solved the issue by adding fuel pressure. he's up to about 70psi fixed to solve the issue of the ECU adding fuel due to the engine running lean. His car is s/c'd.
Mitch's car is N/a, and he discovered the whole issue is that the diameter of the intake pipe is too large where the MAF is positioned. The MAF can't properly read the amount of air going past it and into the engine. So, the car is getting more air than it thinks, running lean for the amunt of fuel its dumping in.,
177Hp/186Tq Stock and OBDII compliant...
Dyno
DaveMush
Postby SC V6 » Fri Mar 31, 2006 6:52 am
I'm guessing your exhaust is restrictive as well... not saying that makes you run lean, just a helpful hint while searching to make your car run better
SC V6
Postby Akfahad » Fri Mar 31, 2006 7:46 am
Mole wrote:does jim's mod involve bigger injectors?
No it doesn't.
Dat, get your SAFC hooked up and get it to a dyno. You don't want to have your car running lean.
Josh
Postby Ian » Fri Mar 31, 2006 8:00 am
Amazing. It looks like you've done everything necessary to at least run safe boost at 4psi. I don't know what to say.
Should we go back to the stock intake and get rid of the Injen CAI? Otherwise, it seems that you have to dyno tune regardless of what boost you run.
That's disheartening. What I will say is that I'm not planning to invest anymore in this car. I think I've spent enough. If something goes wrong, then I'll have to go back to stock.
Ian
Postby SC V6 » Fri Mar 31, 2006 9:30 am
well the issue is that the fuel systems probably have times where it dips lean running 4 psi... this car has issues w\ fuel and how the heads get the exhaust out of the car... This car probably should have had a larger fuel setup for the supercharger included in the kit from TRD... I am running supra injectors, lower compression heads, headers, high flow y-pipe to a 3 inch exhaust back, as well as a MSD ignition, safc-II and various other modifications... and I am running 4 psi just fine w\ no issues... I think this car has a major issue running boost.. and a lot needs to be done to compensate for it
yeah I have done a lot and is overkill for 4 psi.. but im running it safely all day long w\o issues
SC V6
Return to Forced Induction
