SolaraGuy.com • View topic - CPE on the boosted?
CPE on the boosted?
CPE on the boosted?
Postby solow1605 » Fri Apr 21, 2006 12:24 pm
I'm about to order the CP-E intake for my gen 1.5 solara. I'm gonna get the tuneable one. Do you all think that this is gonna put out as much power as they "claim" on their website? Also I was having problems with my injen running my system a bit lean, do you think that the cpe will make the car do the same? I understand its a short ram and for the money i think its a good upgrade. Any help is appreciated! Thanks
2003 Anniversary Edition z06. Black on black...seeexxy
solow1605
Postby krook » Fri Apr 21, 2006 12:37 pm
i already contacted RPM to see if it was safe to put the CP-E intake on an S/C'ed application, and they said it wasn't since they haven't found anyone to test it yet.
try and contact them again though, to see if they have someone now...
krook
Postby solow1605 » Fri Apr 21, 2006 12:38 pm
well if we tuned it ourselves (i'm getting my car dynotuned) i wonder if it would work out. It cant be THAT hard can it?
solow1605
Postby Sentinel » Fri Apr 21, 2006 12:43 pm
I would think that the tuneable one would be perfect for the intake on something boosted. Its already got the ECU tinkering built in.
Sentinel
Im in..
Postby JMSinMaryland » Fri Apr 21, 2006 3:11 pm
I've contacted them before. I'm like 30 minutes away but they weren't too eager after the lack of support with their NA intakes. Jon. p.s. if they've changed their minds Im willing to work with them.
JMSinMaryland
Re: Im in..
Postby krook » Fri Apr 21, 2006 3:37 pm
JMSinMaryland wrote:I've contacted them before. I'm like 30 minutes away but they weren't too eager after the lack of support with their NA intakes. Jon. p.s. if they've changed their minds Im willing to work with them.
well, if they DO change their minds and they make one that's safe for our SC's to work with then i'll get one too. i don't bullshit.
krook
Postby solow1605 » Fri Apr 21, 2006 5:53 pm
yea really, i'm looking at the money now shiieet.
solow1605
Postby dominoSLEV6 » Fri Apr 21, 2006 7:22 pm
I'm sure it's safe, you just may have to do some tuning. I think their fuel map is set for a 1MZ N/A automatic. So if you're anything else you're probably going to have to make some adjustments. I've been running mitrous with mine and haven't pulled a CEL to this day. Your best bet would be calling Josh from CP-e to see what he thinks about it. He knows how the fuel map was set up etc, and I'm sure he could point you in the proper direction to tune with his tunable programmer.
Another thing I've been meaning to bring up. Do you guys think their little tunable version works just like an AFC that you'd plug into your OBD-II? I was wondering why it would really be much different since it's all changing your fuel map using your ECU. Eh, I dunno tho. Hope you get a nice setup going with the CPE and SC.
-chris
dominoSLEV6
Postby solow1605 » Fri Apr 21, 2006 7:39 pm
In all honesty I dont know how to tune this stuff. Can someone offer some advice so i can get this thang started
solow1605
Postby DatSRBoi » Fri Apr 21, 2006 10:50 pm
Yeah I know im running way too lean. I need new injectors to fix that issue im hoping. The other only issue I have right now is seeing soo many people hitting these numbers and blowing their motor after so many said it was safe. I need to to run safe at this level without issues.
Postby Sebas007 » Sat Apr 22, 2006 5:30 am
DatSRBoi wrote:Yeah I know im running way too lean. I need new injectors to fix that issue im hoping. The other only issue I have right now is seeing soo many people hitting these numbers and blowing their motor after so many said it was safe. I need to to run safe at this level without issues.
Yeah, too lean is our ennemy
Postby Sebas007 » Sat Apr 22, 2006 5:40 am
From what I know.
I'm not a pro but I think I got the pattern right.
the fuel map is set with the RPM on the Y axis and volts on X axis
The volts go from 0 to 5 (it's the intensity you hit the throttle)
Then the RPM is the RPM , you know
So you want a 14.7 air/fuel ratio on low RPM and low volts
You want 13.7 (my estimate) air/fuel ratio on high and low volts
About the same on low RPM and high voltage
Now the performance zone, "high" RPM (starting at 4400) and high voltage (around 3.7 = 75% throttle) around 13, I would put 12.7 air/fuel ratio.
I did some dyno runs and there I learn so many things about it.
Again why don't you call CP-e or a an other tuning professional ?
Postby solow1605 » Sun Apr 23, 2006 2:35 pm
I told them i'd do the tuning if they'd hook it up with a discount. They said no WAY. I was kind of sad, but I dont wanna be the first to do this. So i'm waiting for someone else with more knowledge to do it first. lol So anyone up for the task?
solow1605
Return to Forced Induction
