Spark Plugs
What spark plugs are recommended to use with a s/c v6? Are OEM plugs ok or should I use a colder heat range?
Cheers,
Shawn
Cheers,
Shawn
- smacd11
- Just Licensed SolaraGuy
smacd11 wrote:Thanks for the reply. TRD sent me a response to the question stating that they recommend the OEM plugs with the S/C.
If I was smart I would have replaced them when I installed the blower 3 months ago.![]()
Shawn
PDX SuperSolara wrote:I have had various failures of the Iridium plugs in the SuperSolara so I switched to a plug used in the BMW M cars. It has four cathodes instead of just two on the stock plugs and is a platinum plug as well. They have been flawless. It is a NGK. Part number is BKR6EQUP. Stock number is 3199.
facevedo17 wrote:I was told that denso Ik22 aren't for our cars we need Ik20 how true is this ???? is there a difference ????
QuickSEV6 wrote:PDX SuperSolara wrote:I have had various failures of the Iridium plugs in the SuperSolara so I switched to a plug used in the BMW M cars. It has four cathodes instead of just two on the stock plugs and is a platinum plug as well. They have been flawless. It is a NGK. Part number is BKR6EQUP. Stock number is 3199.
Jim, I just ordered a set of these.
By any chance, do you know what kind of gap I need?
Thanks
Users browsing this forum: No registered users and 80 guests
