SolaraGuy.com • View topic - PO 171
PO 171
PO 171
Postby cartang » Fri Jun 23, 2006 4:00 pm
Hi : Engine ligth coming on code,PO 171 , The camry ( 99 , SC ) was taken to the dealer , changed air flow meter , check all leaking tubes , the code still come in any help thanks
cartang
Postby krook » Fri Jun 23, 2006 5:36 pm
whate colde is PO box171?? eye'm knot shure if i got taht colde, butt you shuld check ure noc sensore
krook
Postby StockSolara » Sat Jun 24, 2006 12:14 am
krook wrote:whate colde is PO box171?? eye'm knot shure if i got taht colde, butt you shuld check ure noc sensore
P0171 – System too lean
· Loose air intake hose or duct
· Incorrect fuel line pressure
· Obstruction in injector
· Heated oxygen sensor malfunction
· MAP or MAF sensor malfunction
· ECT sensor malfunction
Do you have an intake? That is one of the main cause for this code to several members here. . . Replace the stock air box and it will be fine
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby SolaraGuy22 » Sat Jun 24, 2006 1:13 am
LOL, you're going to hell. :D
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Return to Forced Induction
Users browsing this forum: No registered users and 64 guests
